Results 1 to 8 of 8
Thread: Anyone get XM to work?
    Dec 2007
    I've got an xmpcr here and am having no luck getting jxm, amp, or macxm to work. Seems I'm missing the javax.comm dealie. Installing it seems over my head. Downloading xcode right now to see if I can follow along with rxtx.org wiki.
    Gotta get this done quickly and I'm thinking of just running bootcamp and windows xp (will it even work then?)
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    if installing javax.comm is over your head then doing anything with Xcode will drown you.
    Bugbyte said he will be porting my cocoa native XM module code to AMP in coming months. that does not require javax.comm and is fully compatible with the XM PCR
    check us out at: www.neonboombox.com
    Dec 2007
    Wow you really saved my a** here with your prog.
    How about that? A program that works right outta the box!
    I appreciate the hard work that goes into developing all these front ends, lord knows it's over my head.
    Thanks everyone.
    Feb 2008
    no problem, I'm sorry it doesn't work as well as I would like
    IIRC the java based ones didn't work all that smoothly either... hopefully bugbyte or somebody else who cares more about XM then myself will really put some time into it and make this native solution better.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yep, we'll *be* working on it. Which means that we aren't working on it just yet.
    You have to install that javax.comm module into java to get it to work, but I don't think that AmpXM works with the XMPCR. At least, I haven't tested it with an XMPCR.
    Want to:
    Newbie minicoopS007's Avatar
    Sep 2005
    Gaithersburg
    Quote Originally Posted by Bugbyte View Post
    Yes we (bugbyte and minicoopS007) need to work on it. I've started on the integration into AMPXM (AMP 1.x)...
    Cheers
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by NeonDev View Post
    I took a look through the code. Thanks for commenting it and making it easy to read!
    We'll get working on it for AmpXM.
    Want to:
    Sep 2005
    Gaithersburg
    Question iAmp/Amp2/AmpXM/Amp_TV
    I call it iAmp; also known as Amp2/AmpXM/Amp_TV. In any case I have integrated the cocoa XM code from NeonDev into iAmp. Kudos NeonDev! My version of iAmp runs under OS 10.4.11. Bugbyte will build it under leopard. I use powermate and or keyspan IR remote to control iAmp. With powermate I can't simulate the "esc" key input. I could write an applescript to perform this, but I was hoping someone here has already done it. This is really a minor issue. The core issue I'm having is with the Mp3Car USB adapter for XM Direct. The device (Mp3Car USB adapter for XM Direct) appears under usb hardware profile. I thought this device was an FTDI usb<-->serial compliant. The device does not appear under /dev/cu.* or /dev/tty.*. Also it does not appear in the network port configuration. I have FTDI drivers installed.
    Note that I used to be able to control my XM Direct tuner with HXM via my DIY usb-serial cable.
  1. XM Radio - COMPLETE REWRITE
    By mitchjs in forum Road Runner
    Last Post: 07-16-2008, 12:17 PM
  2. XM Direct + Serial = Mouse?
    By jpsndtek in forum Hardware Development
    Last Post: 12-23-2007, 01:56 PM
  3. XM to the Carputer
    By TokyoJoe in forum Hardware Development
    Last Post: 09-13-2006, 09:03 AM
  4. How do I get the XM direct unit to work?
    By minghi in forum Off Topic
    Last Post: 04-22-2005, 06:52 PM
