i downloaded the frontend but when it asked me to choose the file HXM i picked the wrong one file how can i fix it?
Printable View
Try trashing the HXM prefs under Library-->Preferencex-->HXM
Try looking for the ampxm preferences in there as well. Trash those if you find them.
Make sure you have the HXM program on the computer and that it is working properly.
ok i fixed it but when it promts me to pick HXM i click on the HXM folder but all the stuff in side is faded so i cant pick any of them any ideas
Have you run HXM separately? It is a java program. You should be able to run it without Amp and set it to operate your XM device. If it is faded, it sounds like you don't have java installed?
You also need the LineIn program to allow it to play through your speakers if you are feeding the XM Direct output back into the computer.
