Page 5 of 5 FirstFirst 12345
Results 41 to 42 of 42
Thread: Another Android Tablet thread...
  1. #41
    GUS
    GUS is offline
    Low Bitrate GUS's Avatar
    Jan 2006
    Sweden
    Now we are talking, that is the way it should be, only por thing with android is the lack of drivers for additional peripherals, either you get a device that has "everything" or you will miss out funcionality. But this might change as the market grows hopefully.
    www.longway.to
    Mina bilar
    Roadtrip to Murmansk
    Roadtrip to Odessa
    20 cylinders, about 650 hk Mercedes
    MB 560SL -86
    MB SL600 -94
  2. #42
    May 2012
    Grandville, MI
    Quote Originally Posted by GUS View Post
    If you go to http://imxcommunity.org/ you can do searches on these and they are VERY helpful.
    The i.mx53 Quick Start board will only do 1 HDMI output with an add on board but the base board as mentioned previously is $150.
    The i.MX6 processor series is very new at the moment and they don't have a quick start board. The one I listed is a Development board from another company that costs about $300 but has the HDMI port already built in.
    BOTH boards are ARM based but the difference is the 53 has been out a lot longer and has drivers available for a lot of things. The 6 series can be hard to get a hold of drivers for because it is so new still. BOTH boards come with Ubuntu but you can download Android 4.02 or WinCE7 for them. The source for Android and Ubuntu I believe are free due to their licensing but with the WinCE7 you have to purchase the source code if you want to change what base options the OS loads with. Trimming the OS's in any of these versions is the trick once you have your setup done. If you are doing a simple CarPC with this I would doubt seriously you would want to mess with the source at all unless you are adding drivers for some device.
    Sorry if I duplicated any information I already mentioned. The Via or a Atom based board would be cool to play around with at the size of the PI. The intel NEXT board will be nice since it will be able to run standard windows on a computer not much bigger than a credit card.
    Rodney
  1. Hot Chicks Thread - NOT WORK SAFE
    By ODYSSEY in forum Off Topic
    Last Post: 05-17-2005, 10:38 PM
