Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Nook Color Install Mustang GT
  1. #11
    Jul 2010
    I unplugged the nook from power and the noise stopped. Maybe its the cheap chinese usb adapter? or maybe I should hard wire an accessory connection to the harness adapter?
    Quote Originally Posted by badmonkey23 View Post
    Sorry, didn't realize you had your mini-amps wired directly to the battery, try running the nook off the same harness that the equalizer is running off, bypass the accessory plug. I had the same noise issues when I was running my ipod and iphone off the accessory plug.
    Not sure if it's ok to run the nook directly off the battery or not, unless there's a voltage regulator between the battery and the stereo harness. I've been running my ipod and iphone off the stereo harness for over a year.
  2. #12
    Jan 2008
    the noise is definitely a ground loop. ground loops are caused when different devices have different resistances to passing voltage to ground. in a perfect world, this resistance would be zero-- which would mean that you wouldn't have problems...
    as bad monkey said, a common fix is to try to connect everything to the same power points. the other common causes are poor grounds--either from a loose/corroded connection, or from a generally poor connection. if your using the factory ground connections for some devices, but sanded the paint off the area for other devices, the factory ground could be a poor connection.
    or, as you started to suspect, a single devices poor power supply could cause noise issues as well.
    another really easy thing to try is to connect a wire between the negative part of the rca, and ground. sometimes this will drain the noise off the line..(but it doesn't always work, or can make the noise louder-- so be prepared to take it off real fast)
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  3. #13
    Jul 2010
    So would connecting to the harness 12v and ground be the better option?
  4. #14
    Jan 2008
    first, try it the way that badmonkey recommended, where the nook uses the same power as the other audio devices. if that doesn't work, then i would try a different power source.
    HID retro--100%
  5. #15
    Apr 2011
    Hey im a noob at this and I was wondering if we all can maybe get some type of writeup to this magnificent project you just did! I want to do something similar to my car and im not sure how. thanks.
  6. #16
    Jul 2010
    yeah no problem, I have all of the photos from the begining since I knew knowbody fabbed a nook color into a dash yet.
    Quote Originally Posted by fsolano8812 View Post
  7. #17
    Apr 2011
    okay cool. wanna PM to me or just upload them up on this thread.
    Quote Originally Posted by brian31389 View Post
  8. #18
    Jul 2010
    I will put it up under the show off section. Also my luck ran out and when I was trying to fix the noise the usb cable on the nook end broke!!! very lame, also my 8gb micro sd is dead.... Obviously my luck ran out. That and I cannot get rid of the noise! I tried a power filter connected to a different and same power source but still the annoying buzzing continues :,( Maybe I should start from the begining and wire the amps straight to the battery and everything else through the harnes(equalizer and nook)?
  9. #19
    Jan 2008
    i vote to connect everything to a direct run from the battery, and a ground point that you install-- not using any of the factory ground points..
    splitting up where everything gets power from is what is causing the noise issue in the first place, so the less differing-voltage sources you can use, the better your chances of correcting those issues.
    HID retro--100%
  10. #20
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Or use a regulated psu just for the nook, if you can determine that the nook on battery makes no noise. If on batteries the nook is fine, don't touch the eq... I can't guarantee it will work, but if you have one dc dc psu laying around...Or you could try amazon, free shipping and np tax for me,and free no hassle return, something like this http://www.amazon.com/Picopsu-90-Dc-...967551&sr=8-10
  1. Nook Color B&N ebay store for $199.00 ($50 off) until March 3rd
    By RipplingHurst in forum Android Tablet
    Last Post: 03-01-2011, 04:29 PM
  2. 2007 Mustang Install (first car pc install)
    By Hessian in forum Newbie
    Last Post: 06-28-2007, 07:44 PM
  3. 02 Mustang GT color codes
    By Buddy16 in forum General Hardware Discussion
    Last Post: 04-13-2007, 08:05 AM
  4. 2006 Mustang GT Install
    By maxjet in forum Show off your project
    Last Post: 06-12-2006, 09:06 AM
  5. 65 Mustang Install
    By 65coupei6 in forum Worklogs
    Last Post: 09-08-2005, 06:56 PM
