Results 21 to 30 of 36
Thread: Nook Color Install Mustang GT
  1. #21
    Jul 2010
    well I can have audio images fix it since they did the wiring because im so busy. Ill still make the post on the show off section though as it does work fine except the buzzing.
  2. #22
    Jan 2008
    i know it is just a suggestion, but that pico-psu doesn't regulate the 12v line-- so if you try to use it for 12v regulation, its a waste of money..
  3. #23
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Oh didn't know that, I thought all those did that.
    Thanks soundman, and sorry OP.
  4. #24
    Jan 2008
    no problem.
    hopefully that also answers why mini-box makes pico-psu, and m1/m3 variants!
  5. #25
    Jul 2010
    I agree that it all should go directly straight to the battery, I was making the point to them originally but they used the harness instead. well I will have them switch it this week and then when the usb cable comes in and everything is connected ill have a video up and a project page in the show off section. Thanks for all of your suggestions and help, much appreciated
  6. #26
    Jul 2010
    Here is the video of the bench test http://youtu.be/YXsbkoP2dtM?hd=1
  7. #27
    Jul 2010
    I use my droid x as a internet/gps dongle. Ok guys turns out that all the suggestions didnt work but I did solve it. I bought a power inverter from radioshack for 30$ that was 75w and no fan so it made no noise. Works flawlessly and I will put up a worklog shortly.
  8. #28
    Dec 2007
    Danville, CA
    Thanks to people like you, I just got myself a used nook color... awesome screen, I'm impressed. Upgraded it to 1.2; but I'm going to root it of course.
    Any pointers I can't miss? Just bought a left angle micro usb cable for charging it in the car, if I just feed 5v @ 2.1A I should be able to charge it fine? Or do you HAVE TO use nook's oem? Do you have yours completely discharged often?
    Any pointers on rooting (I'm heading to androidtablets.net/XDA for reading right now), pitfalls? What size SD card do you use, and do you use BT headset to listen to music with Cryanogen (sp?)?
    Thanks, and good news you got your problem solved. Can't wait for the worklog.
    Cheers,
    ---------- Post added at 09:52 PM ---------- Previous post was at 09:48 PM ----------
    Great video btw, good job on the buttons and bezel. You need better apps with bigger fonts buttons, perhaps? Did you overclock that thing, it looks faster than mine (stock)...
  9. #29
    Jul 2010
    Quote Originally Posted by RipplingHurst View Post
    Cheers,
    If youre going to root the nook get phiremod, its the best and it has TONS of support which is great. Also I just use the stock charger plugged into a 75w power inverter thats plugged into an accessory outlet wired to my 12v constant harness so its always powered. (nook is overclocked to 1.1ghz btw) youre on the right track for rooting the nook. I just used a 8gb card since thats what I had sitting around and it works great. I dont use a headset because its wired through my car speakers so theres no reason for me.
    Yes its overclocked but like i said in the video that it was running the older version of phiremod, now its 6.1
  10. #30
    Oct 2007
    American Fork, Utah, United States
    i know you've already figured out your noise isolation issue but here is a good site to reference on ground loop isolation and electrical noise as i am trying to avoid this myself with my current install. http://www.termpro.com/articles/noise.html
  1. Nook Color B&N ebay store for $199.00 ($50 off) until March 3rd
    By RipplingHurst in forum Android Tablet
    Last Post: 03-01-2011, 04:29 PM
  2. 2007 Mustang Install (first car pc install)
    By Hessian in forum Newbie
    Last Post: 06-28-2007, 07:44 PM
  3. 02 Mustang GT color codes
    By Buddy16 in forum General Hardware Discussion
    Last Post: 04-13-2007, 08:05 AM
  4. 2006 Mustang GT Install
    By maxjet in forum Show off your project
    Last Post: 06-12-2006, 09:06 AM
  5. 65 Mustang Install
    By 65coupei6 in forum Worklogs
    Last Post: 09-08-2005, 06:56 PM
