Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Nook Color Install Mustang GT
    Jul 2010
    Hey everyone, I'll make this short and informative for others to follow. Bought a nook color from barnes and noble ebay store shipped and tax for 220$ it has been rooted with phiremod 5.1 and has bluetooth enabled. I hacked it open and extended the wires for all the buttons so they can be moved. I dont have pictures to put up of the nook as my buddy who owns audio images here in the bay is fabricating it into the frame. Even though I don have a shot of the nook color I do have my audio setup that sounds amazing and very cheap so here it goes.
    2x- road rage amp-150w (75rmsx2) (30-60$ each)
    -Clarion equalizer eqs746(50$ ebay BIN)
    3x-6ft rca cables
    -rca aux adapters
    4x-kenwood 6 1/2 mids (70$ BIN for all 4 ebay)
    I tested them with my rooted droid and they sound amazing, the clarion equalizer makes a huge difference in sound. I will have my nook color done on monday Ill post pics once it is done and I will be more than happy to help.
    Photos will be up soon
    there you go
    Jul 2010
    woot I am done, photobucket is down right now but photos will be up soon. video will be up soon
    Jul 2010
    Newbie craigbru's Avatar
    Jan 2011
    Nebraska
    Sweet looking install man!
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    That is absolutely fantastic. Have you tried running tasker yet to automate stuff, does it work for you? How is HD video playing? That was the thing about buying those to use for my second row passengers, I heard there's no hardware acceleration to play HD movies (say from family movies taken while away from home, etc.), while other tablets can.
    How do you do updates? Over the air? Do you sync with a computer for songs, etc? How about an SD card (the nook has one, right?).
    Thanks for posting the pictures, please keep us updated.
    Jul 2010
    I use my rooted droid x to share internet and gps for the nook. it plays hd really smooth (it is overclocked to 1ghz) and I use pandora and dropbox flawlessly. The nook color has a microsd, what is really great is the fact that it boots from sd before internal memory so its pretty much unbrickable. I haven't tried tasker yet but it seems to be running just fine with phiremod 5.3 rom. Also the nook color has a beautiful screen that can be seen at all angles in my car and even in sunlight.
    ---------- Post added at 12:49 AM ---------- Previous post was at 12:42 AM ----------
    Cleaned up the equalizer a little bit
    its now in the dash
    ---------- Post added at 12:52 AM ---------- Previous post was at 12:49 AM ----------
    Also Im thinking to plug it into the accessory 12v on the harness. the nook originally turns on automatically when plugged into the wall so it somewhat has ignition start feature. I would like some assistance from some audio techs out there that can help me with all the constant hissing and static I get now. Any help and suggestions are appreciated.
    Dec 2007
    Danville, CA
    I agree that the screen in awesome. Very nice equalizer there.
    I got that noise too when I connect the iPad to accessory 12v plug. But when I use my M4ATX PSU, I got nothing, it's as if it's on batteries. I think there must be a filter somewhere to connect to the 12v plug?
    Nov 2008
    Quote Originally Posted by brian31389 View Post
    I'm no audio-tech, but try and make sure your amps, your 12v accessory harness (and probably your equalizer as well), all ground at the same point. You may also need to put in a ground-loop-isolator like I did.
    Edit: Actually, best not to use the 12V accessory harness at all. Those 3 power wires going to your amps, splice the power for your Nook in parallel with those as below.
    Jul 2010
    I have my two small amps connected straight to the battery while the equalizer is powered through the harness. also everything is grounded through the harness as well. The nook is getting power by using an extra accessory plug like you see on my face plate (the one on the face plate doesn't work because of this), I believe this is the problem. maybe I should power the nook through the harness instead???
    ---------- Post added at 10:41 AM ---------- Previous post was at 10:39 AM ----------
    Wouldnt splicing the nook into those wire be somewhat dangerous in a sense that its not a constant 12v but 12v-30v from start up and fluctuation?
    Quote Originally Posted by badmonkey23 View Post
    Nov 2008
    Sorry, didn't realize you had your mini-amps wired directly to the battery, try running the nook off the same harness that the equalizer is running off, bypass the accessory plug. I had the same noise issues when I was running my ipod and iphone off the accessory plug.
    Not sure if it's ok to run the nook directly off the battery or not, unless there's a voltage regulator between the battery and the stereo harness. I've been running my ipod and iphone off the stereo harness for over a year.
  1. Nook Color B&N ebay store for $199.00 ($50 off) until March 3rd
    By RipplingHurst in forum Android Tablet
    Last Post: 03-01-2011, 04:29 PM
  2. 2007 Mustang Install (first car pc install)
    By Hessian in forum Newbie
    Last Post: 06-28-2007, 07:44 PM
  3. 02 Mustang GT color codes
    By Buddy16 in forum General Hardware Discussion
    Last Post: 04-13-2007, 08:05 AM
  4. 2006 Mustang GT Install
    By maxjet in forum Show off your project
    Last Post: 06-12-2006, 09:06 AM
  5. 65 Mustang Install
    By 65coupei6 in forum Worklogs
    Last Post: 09-08-2005, 06:56 PM
