Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 82
Like Tree1Likes
Thread: Android Tablet In-Car Sliding Dock using hacked DVD drive
  1. #21
    Newbie HateWheels's Avatar
    Apr 2011
    Mid-West
    I agree that a mechanized tray would be pretty cool. I really like the hidden IPod / Android set-up. Are you looking into the new iphone app development to see what would work best in your car? Hiding all your little expensive pieces is a great idea, of course. Do you happen to have any more pictures in different angles? I'd love to see this thing in action.
  2. #22
    Aug 2011
    Tipp City, OH
    This looks amazing dude... I love it. I am working on something similar, but the one I am working on will be hinged at the bottom and tilt out foe insertion/removal.
  3. #23
    Aug 2011
    Nice job!.
    I'm doing a similar project with the Viewpad, but I've tried some car chargers (even two 5V/2A output) without success.
    The charger speed is not enough to maintain the charge.
    Could you tell me your car charger reference? Thank you a lot!
  4. #24
    Nov 2008
    I'm just using a generic cigarette-to-usb adaptor. Are you plugging yours into the cigarette socket? Maybe it's a limitation of your socket? I have mine hardwired to the car as follows.
    Or maybe it's the USB cable? Are you using a data cable? Maybe you need a dedicated usb power cable with 2 wires, maybe it restricts the amps if it thinks it's plugged into a usb port on a pc. I went through a few usb cables because I needed one I could hack down and fit into a tight spot.
    Re your PM, don't have my tablet infront of me, but it's just one of the options, think it's Display and then set it to Always On. I think there's a bug with Android though, where if even if the screen timeout is changed, it won't actually take effect until the screen is touched. When I started my car, the screen would timeout, but I fixed that by getting PowerAmp to start up and in PowerAmp I set the option something like "Leave screen on when running".
  5. #25
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    This is a badass install man. Hows the speed of the viewsonic tab? Are you happy with its performance?
  6. #26
    Aug 2011
    Thanks a lot, badmonkey!
    I will check it with a generic car charger. I was using a USB charger and a data cable, because I thought all them were identicals.
    Anyway, what's the difference between your car hardwiring and standard cigarette plug? My cigarette plug only works when I ignite the car, so might be the same result, isn't it?
    In terms of performance, I only had problems with OBD2 "DashCommander", because it has too lag. I'm using Torque which is near real-time. Are you agree?
  7. #27
    Nov 2008
    It's not too bad, the only times it's felt slow is the built-in browser, but I installed Dolphin and that was much quicker. And Angry Birds Rio. Last week I also rooted it and flashed it with a new ROM that overclocks it to 800Mhz and enables hardware acceleration, I just hope that doesn't affect the battery life.
  8. #28
    Aug 2011
    I see that original viewpad wall charger has addicional pins than standard mini USB. That's probably why I can't get the same charging speed in my car.
    But, I see badmonkey happy with his generic car charger. Its usb plug is standar? please, could you tell me where have you taken from, or at least, the electrical characteristics?
    And, could you say me a forum to take profit of this tablet?
    Thanks again.
  9. #29
    Nov 2008
    Quote Originally Posted by Jaylo View Post
    I'm thinking it might be possible that there's a max current allowed through your cigarette plug, whereas if you wire your charger up direct to the battery, there should be no bottleneck apart from your charger. Wire it up as per the diagram and it will only turn on when the car is turned on. And it should also remove any ground-loop problems.
    Sorry, can't check my charger, it's pretty jam packed in my din slot - with the mount, the amp, the charger, the ground loop isolator, the plugs and all the cabling, and the moving drive tray, it's pretty tight and everything moves as it's supposed to, I don't want to touch it until I'm ready to upgrade the amp. I think my charger was just one of these http://jaycar.com.au/productView.asp?ID=MP3662
    I never tried Dashcommander, Torque was only $2, mental cheap for an OBD app and a pretty good app too.
  10. #30
    Aug 2011
    Of course, please, don't open your slot.
    It seems the original wall charger -which really charges very quick- is specific for the Viewpad.
    Because, if I use another standard wall charger the charging speed is also very low.
    So, if I use an standard charger in the car I would expect the same results, even directly connected to battery.
    Anyway, in your case, ...it's working!
    Well, I will try what you suggest.
    Thanks again.
    slowe likes this.
  1. Another Android Tablet thread...
    By GUS in forum Android Tablet
    Last Post: 06-04-2012, 03:46 AM
  2. Motorola Xoom tablet car dock
    By live2ride883 in forum Android Tablet
    Last Post: 03-22-2011, 02:25 AM
  3. Xoom tablet car dock
    By live2ride883 in forum Show off your project
    Last Post: 03-19-2011, 03:17 AM
  4. Android Tablet
    By SLimp3car in forum Software & Software Development
    Last Post: 08-10-2010, 01:36 PM
  5. hp tc1100 tablet and dock dash-mount
    By bask0g in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-26-2004, 10:43 AM
Tags for this Thread
