No worries. I'm sure other things are more pressing. Although once you get the app released, I'm pretty sure you'll have quite a few Nook owners wanting to try it out.![]()
And yeah I did look at the second log and its the same error, so not entirely sure what is causing it so ill will take a deeper look into it and see what I can figure out, its on the list of things to do once I get some time off
Ok so i just got my samsung tab 10.1 today so ill be able to customize and handle the layout better now for tablets... However im upgrading my computer and its not liking the new motherboard, cpu or memory so might not have a computer for a couple days
Here is a quick screen capture on my dell streak 7, only crash was received from the constant replay of the facebook pop notification sound as that is the only sound file i have.
Ok so got my computer up and running and after playing with the tablet today, I think im gonna need to make it for the tablet specifically, and then later make a phone version, because there is enough of a difference in the structure that it needs to be customized a seperate app other wise there will be lots of errors
I don't see volume buttons anymore. Will there be a gesture to control the volume? This will be a make or break feature for me cause I hate having to use the physical volume buttons on my tablet.
Hi,
I tried to download and use this at mine samsung galaxy tab, it's still running 2.2.
when i try to fire up the launcher, it crashes to this error message.
Sorry!
The application AndCar (process DRing.AndCar) has stopped unexpectedly. Please try again
[Force close]
Am i doing something wrong ?
I had the same problem, and so did NightJumper when he first got his Tab. He found a temporary fix. If you don't have any music files loaded, go ahead and add a few and try again. You might find that it fixed the issue.
Thanks for the respond,
now i just have to wait a car mount for the tab, I have opened up my desktop dock and try to replace the inside guts of vehicle mounts electronic parts so i could get a 3.5mm audio connector to it.
One bug what i noticed was the play/pause icon doesn't always change into the II pause symbol. How about the navigation software audio parts? Does em override the playing song and mute or particular mute it during the voice guidance tip?
about the hardware of samsung tab, i also noticed when i opened up the hdmi media dock that there's a rx/tx/gnd connectors unconnected.
