Results 1 to 7 of 7
Thread: Porting Linux Drivers To Android
    Oct 2004
    Israel
    Hi
    I'm in middle of my own Android tablet project ( using Nook Color )
    trying to get some devices working with USB HOST ( OTG )
    I saw a couple of cool projects here , and I wondered if someone here tried porting some car-pc hardware drivers to Android?
    My main goals are :
    1.Contour ShuttleXpress
    2.GlobalSat BU-353
    3.DCDC-USB
    I don't have any coding skills in linux ( I don't even know how to compile but it seems pretty easy ) , but I'm willing to learn
    And if someone here already done some progress or have knowledge about the things needed to make driver ports and willing to share it would be a great step forward
    Here is a post I made on the NC usb-host thread on XDA with logs and info on the ShuttleXpress and BU-353 : http://forum.xda-developers.com/show...&postcount=587
    The DCDC-USB psu should be here soon I hope
    and here are the drivers for Linux : https://gitorious.org/minibox-dcdcus...b/trees/master
    Again , any help would be grateful so don't be shy
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Oct 2007
    American Fork, Utah, United States
    i haven't seen any porting of drivers to the android platform that i know of but the honeycomb platform does have peripheral driver support i believe and there are definately alot of interesting projects going on to port things back and forth between traditional x86 and portable devices.
    Oct 2004
    Israel
    Normal devices do work right out of the box without any porting because of the built-in drivers ( keyboards , mice etc. )
    But special devices needs porting , I found some info on how to port and I'll be starting figuring out how to do it in the next few days hoping for some quick results
    First I need to probably setup vm for compiling before I start messing with the code
    Aug 2011
    Post how to access linux I2C keypad device driver in Android
    Hi,
    Actually i need to Access linux device driver i.e. I2C keypad/mouse, etc.. in Android
    but i don't find the solution how to Access it, so can anyone help me in this.
    Thanks a lot.
    BR
    Maddy
    Oct 2004
    Israel
    Updates for anyone who is interested
    I'm hoping the GPS will work on the next kernel release , with this commit
    http://review.cyanogenmod.com/#change,7264
    I've made some progress with the ShuttleXpress
    Here is a thread describing where I'm at now :
    http://forum.xda-developers.com/show....php?t=1220621
    the DCDC-USB arrived and I already connected it to the nook to see if its recognized
    Here is the info from dmesg :
    Code:
    <6>usb 1-1: new full speed USB device using musb_hdrc and address 2
    <7>usb 1-1: ep0 maxpacket = 8
    <7>usb 1-1: skipped 1 descriptor after interface
    <7>usb 1-1: default language 0x0409
    <3>usb 1-1: device v04d8 pd003 is not supported
    <7>usb 1-1: udev 2, busnum 1, minor = 1
    <6>usb 1-1: New USB device found, idVendor=04d8, idProduct=d003
    <6>usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    <6>usb 1-1: Product: DCDC-USB
    <6>usb 1-1: Manufacturer: MINI-BOX.COM
    <6>usb 1-1: SerialNumber: 1.00rel.
    <7>usb 1-1: uevent
    <7>usb 1-1: usb_probe_device
    <6>usb 1-1: configuration #1 chosen from 1 choice
    <7>usb 1-1: adding 1-1:1.0 (config #1, interface 0)
    <7>usb 1-1:1.0: uevent
    <7>usbserial_generic 1-1:1.0: usb_probe_interface
    <7>usbserial_generic 1-1:1.0: usb_probe_interface - got id
    <7>usbhid 1-1:1.0: usb_probe_interface
    <7>usbhid 1-1:1.0: usb_probe_interface - got id
    after I'll work out the gps and shuttlexpress I'm planning to try and port the dcdc drivers
    Jan 2002
    Philadelphia
    Interesting stuff. As you know from another thread I am looking at doing the same thing for an AM/FM radio. I will be following this closely.
    Oct 2004
    Israel
    Quote Originally Posted by maddilety View Post
    Hi,
    Thanks a lot.
    BR
    Maddy
    Which drivers exactly are you trying to find?
    What do you want to do? key mapping?
    Try in your kernel source @ drivers/input
    If you can't find it share the github link or specify the device and kernel you are using
    Quote Originally Posted by mhermann View Post
    Which radio module did you decide to try and port?
    At the bottom I'll post a list of sources that might help you
    So some updates :
    - A friend of mine who know more about coding should be here tomorrow to help me get some progress done
    - I made some progress with the GPS , info : http://forum.xda-developers.com/show...&postcount=642
    It seems we need some app like BT GPS just for USB
    Sadly , I don't have enough knowledge atm to write this kind of app - maybe in the future if there will be no-one intersted
    Here is some sites/documentation I've used to help me start and still uses as a knowledge base ( not all related to android )
    http://source.android.com/source/initializing.html
    http://tldp.org/LDP/lkmpg/2.6/html/x380.html
    http://kernelnewbies.org/
    http://yidonghan.wordpress.com/categ...dded-software/
    http://www.linuxjournal.com/article/7353
    http://cianer.com/androidg1/28-build...-kernel-images
    http://blog.linuxconsulting.ro/2010/...o-android.html
    http://forum.xda-developers.com/show....php?t=1078668
    http://groups.google.com/group/taske...64e6f88aa3ddcb
    http://forum.xda-developers.com/showthread.php?t=915435
    http://wiki.cyanogenmod.com/wiki/Bar...ogenMod_(Linux)
    http://wiki.cyanogenmod.com/wiki/Bui...el_from_source
  1. Linux drivers for Lilliput Touchscreen?
    By Visual Echo in forum LCD/Display
    Last Post: 03-24-2015, 10:11 AM
  2. Are there Linux drivers for Fusion Brain?
    By Maheriano in forum Fusion Brain
    Last Post: 11-28-2008, 05:39 PM
  3. EPIA (800) Linux Drivers?
    By Dillusion in forum Operating System Optimization
    Last Post: 05-08-2005, 03:21 PM
  4. Linux Drivers for Lilliput Touchscreen
    By ciagon in forum Input Devices
    Last Post: 04-26-2004, 06:46 PM
  5. Replies: 2
    Last Post: 02-24-2004, 02:17 AM
