It all comes down to the speakers, and my stock speakers are garbage.
Anyways I fabbed up some mounting brackets for the rear deck, installed some infinity full range speakers there for fill.
Replaced front door speakers with infinity components
Running a 5ch Alpine PDX-5 and a Kicker EQ9 with a Miccus BluBridge mini-jack Rx
It works, however it doesn't have much volume. I'm going to add a PAC LD10 line driver to it so I can boost the signal and not have to max out the phone (which can cause distortion)
UPS crushed my subwoofer... have to order a new one but they are out of stock and backorder is 1 month.
After I get the sub installed and the line driver, I'm going to add a couple usb ports to the car so I can run the Miccus BluBridge continuously, as well as fab a phone dock to replace the stock
head unit.
Also, my my window quit rolling up for some odd reason, it rolls down though. There was moisture in the door, I think the motor might've shorted. Going to pull it out today and check.
Still trying to think of a good way to set up a remote turn on that will eliminate the pop, atm I have a button for my remote wire that turns it on and off, which may become the permanent solution.
