Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Tablet As Bluetooth Headset
  1. #11
    Jun 2010
    Slovenia
    HI, i 'm looking for the same possibilities.
    I have a carpc in the car with windows sistem and Centrafuse software. I can listen the music, use navigation, passengers can watch video, play games, with 3g dongle or Wifi connection can use the internet. I can connect my phone via Bluetooth for hand free call ect...When I call or recive the call music automatic mute and play on when cals endet. The Same with the use of Navigation.
    I like this:
    1:Combination: Android phone and Tablets.
    Advantage of tablets compared with standard Carpc is lower price and does not require the sometimes complicated installation, and takes up little space. And tablets can be used in home, on vacation in hotel, camping, at work...
    For tablets you need only Car Suction Cup Tablet Mount and connection audio out on tablets and audio in on car radio.
    But it is also true that you have to remove the tablets when you leave the car and still again mounted. Whit carpc just turn on the car and drive away.
    2:Combination: MINIX NEO X5 : http://www.focalprice.com/EH0099B/MI...304ATV_EH0099B
    and 7" Touchscreen Android touchscreen : http://www.cartft.com/catalog/il/1597
    MINIX NEO X5 has 1 x Headphone jack for audio out to car radio aux and 1 x Microphone jack for external Microphone for lphones call.
    In this variant I see the problem that the touchscreen use Bluetooth connection to touch work. And I think it is not possible also connected Phone with Bluetooth.
    Other problem is that MINIX does not have a built-in GPS receiver for Navigation apps. But you can use one USB external.
    And MINIX can be used at home as a Android TV Player BOX
    But the biggest problem is that there is no android apps like Centrafuse to use the Tablet as a carpc.
    I'm surprised that no one software developer thought of this, because Android hardware has great potential for incar use.
  2. #12
    Sep 2013
    Quote Originally Posted by Diablo2424 View Post
    Thanks for the info on Tablet talk, too bad it doesn't route the audio to the Tablet :-(.
    I am going to see what I can find/develop with this... if I can't go anywhere, I think I will just be stock using a BT headset with a 3.5mm output into my EQ and I'll have to switch the input on my EQ when a call comes in. Then the Microphone of the BT Headset I will extend the wires of it and run the mic to my gauge cluster for talking on the phone... I'll just have to answer the call on my phone and switch the input on the EQ.
    Also, if you want to follow updates on this either go to my CarTab worklog, or check this post on XDA - http://forum.xda-developers.com/showthread.php?t=844605
    I've been looking into something like this too.
    I have a 7" Android Tablet mounted in the car connected to an amp via standard ISO connectors which I made up myself. This setup allows me touse GPS, media etc... exactly as you describe. both the phone and the car have TabletTalk which works well as far as connectivity, but the lack of audio was frustrating.
    It seemed that one needed a seperate Bluetooth device to utilise handsfree, but then it wouldn't come through the car speakers, and it wouldn't mute the media.
    I have found a possible solution though. STRIKE iK-1 BLUETOOTH HANDSFREE CAR ADAPTER KIT.
    Apparently this thing connects to a head unit (in our case tablet/amplifier set-up) to do exactly what we're talking about. The drawback is that any phone must be paired to both the tablet AND the Strike ik-1 for this to work, and the tablet and phone must also use TabletTalk. But it seems it would provide exactly what we're after.
    Thoughts anyone before I go shelling out my 'hard-earned' to experiment???
  3. #13
    Newbie Diablo2424's Avatar
    Jul 2006
    Central NJ
    Quote Originally Posted by Aussie Dave View Post
    Based on that product being made in Australia I will take it that is the country you are from, which may make my solution a bit tougher for you to purchase however, I did go about this a different (similar but more affordable) way than using that device.
    I purchased a Samsung HS3000 Bluetooth Headset and mounted it at the top of my headliner (where my sunglasses holder is between my map lights). Then I wired the Stereo output (3.5mm Headphone wire -> RCA Adapter) out from the BT Headset and into my MAIN input on my Equalizer. At the back of my EQ I used RCA Splitters to have both the Headset and the Tablet being input to the SAME MAIN input. I now have my phone paired with both the BT Headset AND my Tablet, so now when I get in the car I connect Tablet Talk and turn on the BT Headset and when an incoming call comes in, Tablet Talk pauses my Music and my phone routes the audio of the phone call through that BT Headset. Being that the headset and Tablet are on the SAME input in my EQ, I don't have to press anything on it to hear the phone call instead of my music. Then when the call ends Tablet Talk resumes my music, without me doing anything.
    Oh and that Samsung BT Headset only costed me ~$32 USD, a lot cheaper than the device you posted. Your method seems like almost the same thing as mine just with a difference device in place of the Samsung BT Headset, so it should work, I just figured using this may save you some money, which who doesn't like to do that!
  4. #14
    Sep 2013
    Okay that's a fantastic find. I didn't realise that TabletTalk would mute/pause the music whilst in the call and then automatically resume it. It would seem then that ANY bluetooth device with an output that could be connected to the Amp/EQ could be used and provide seamless use of the tablet. My next question then is, does anyone know of a Bluetooth Device that turns on/off with the cars ACC? This would preclude the driver from having to turn on the unit separately, and the mobile would pair automatically with both the Tablet AND the Bluetooth device.
  5. #15
    Jul 2006
    Central NJ
    Hmm, that would be nice, instead of me having to turn it on and off every time I get in/out of the car... I guess you could plug it in to power it like I did, then take it apart and pull the built in battery out, then leave the power switch to "On" and it should technically turn on/off with the car, no?
  6. #16
    May 2011
    That Y-Connector works, but it can cause problems if one component fails. It would still be nice to have a built in solution. I know the latest version of PulseAudio (the linux audio stack) supports this out of the box. Perhaps we will see that in the near future on Android as well. Or at least the capability of it.
  7. #17
    Dec 2013
    Quote Originally Posted by ZombieLinux View Post
    What sort of issues could you encounter? In my case I have a factory Bose stereo that I'll be outputting to and a Parrot bluetooth device. Could I damage the tablet or the amp with this Y-connected direction?
  8. #18
    Nov 2015
    Is there still no better solution? I'd also like to use my Nexus 7 in the car as a headset for my Nexus 5 :/
  1. Using PC as a Bluetooth Headset
    By Stryker707 in forum Wireless Communications
    Last Post: 01-23-2007, 02:23 AM
  2. Bluetooth headset
    By gabepage in forum Road Runner
    Last Post: 07-16-2006, 05:18 PM
  3. Anyone use a bluetooth headset as their PC Mic?
    By tbird2340 in forum Wireless Communications
    Last Post: 04-01-2006, 02:33 PM
  4. Using your PC as a bluetooth headset ?
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-16-2004, 06:35 PM
