Results 1 to 10 of 10
Thread: Computer VS Android Tablet???
    May 2009
    Hampshire, England
    Hi,
    I'm doing my initial research for my new install. But can't decide. My Android knowledge is pretty poor, so bare with me. This is what I would like:
    Music, movies, pictures. - I know this works.
    FM radio (not internet radio) - I don't plan on getting 3G so a normal receiver would be good.
    Steering Wheel remote (I have a Ford Focus MK1) - I've seen a lot of talk but no go. Would be nice to see one working.
    Volume knob - I have a griffin powermate that would be nice to use. If not, I'll use a potentiometer.
    GPS - Built in GPS and the right app can do this.
    Removable - I want an OEM build plus being able to clip it in/out.
    Ext HDD for mass storage - I use WD passports, would they work?
    Bluetooth Handsfree with external mic - I have an iPhone that I would like to be able to use hand free with a tablet and ext mic mounted near me. Can I do this?
    Perhaps TV, DAB radio etc (not essential, would be nice. Again not via internet) - I probably won't do this as additional aerials would probably be needed. But saying that I change my mind all the time. So it would be nice to know.
    I know a computer can do all these with additional components, but with a lot more wiring.
    I am quite happy with the frontends that I've seen, and tasker.
    JM
    Car: Ford Focus
    Currently stock setup. Trying to decide on the best setup for me.
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by jellymonster View Post
    Hi,
    I've never seen Android work as a HFP gateway only the other way around.
    Volume knob... depends on if your tablet supports USB host and if Android recognizes the device and if android software knows how to use it. So probably not.
    Steering wheel controls... probably not with a Tablet.
    Ext HDD... requires usb host. I'm not even certain android supports such configurations.
    Same amount of wires. The only difference may be the device placement location. If you can fit the hardware in the dash, it may require shorter cable lengths.
    Right now I've got a tablet in the car running android (which I will replace with real Linux as soon as I can). It's okay for music and nav. Integration is poor though. Android was not designed for your car.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Low Bitrate aziodale's Avatar
    Jun 2009
    Italy Sicily Palermo
    I do not think the situation is so bad,
    for steering wheel control is a problem
    for tv and radio see
    http://www.tizi.tv/en/index.html
    but for wiring I think it is much easier
    look at my example and judge for yourself
    Dec 2005
    Raleigh, NC
    Maybe with an Arduino? I know for sure you can have them communicate over bluetooth, I've done it. Not sure how to otherwise.
    Look for tablets with USB OTG (on the go) functionality.
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by aziodale View Post
    You're right. I don't see any wires in the video. It must be easier! .
    How do you get the screen to turn on/off with the ignition? Does it sleep or shutdown?
    Oct 2004
    Israel
    A lot of misleading info in this thread so I'll make it short and to the point.
    All of the info below uses ICS w/ Root as reference , earlier versions might not be compatible with some of the stuff
    Try to look for a tablet with internal FM radio , although I can't remember seeing one ( only phones )
    You will probably have to mod the antenna or something to get acceptable reception
    If you are a developer - any of the available options for linux with source code can be ported to android ( some might be harder than other )
    A lot of useful tools recently came out to help doing just that
    That way you can use any USB Host capable tablet to communicate with it
    Only thing left is to write an app to control it
    I've said it a couple of times before
    Joycon can be mapped to execute keyboard keys - that's how it works on linux
    The same thing theoretically can work on android
    I've done it with keyboards and ShuttleXpress ( basically any HID device can do this , see the link down below )
    The only thing is I don't have a joycon nor steering wheel remote so I won't test it anytime soon
    If you want to try it , I'll gladly help you
    I'm working these days on my ShuttleXpress
    There are a couple of ways to do it - depends on what you want to achieve ( only volume control? driver-like control? ) and what are your coding skills
    No problems with USB Host on that subject , even with NTFS on a lot of tablets
    TabletTalk is the closest thing right now to that , and the dev is working on audio transfer so we might hear some news soon
    How are you planning on connecting the external mic? I'm experimenting with usb audio
    Edit :
    Sorry just saw the iphone :\ thing , I'll leave the above comment for the android guys
    Anyways , TabletTalk solution might bring a BT profile that could be used with an iphone too - pretty wishful thinking , but maybe try to talk to the dev on xda ( he has a thread there ) and get his thoughts on this
    Same control as android probably won't be possible ( on BT obviously not , on wifi I honestly don't know ) , so don't expect miracles
    Everything can be done depending on your skills , it's a platform that needs developing to suite our needs
    I'm beginning to scratch the surface on usb possibilities here : http://forum.xda-developers.com/show....php?t=1459892
    Hope I helped and sorry if I offended anyone , but some of the replies just weren't true
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Jun 2009
    Quote Originally Posted by tripzero View Post
    for the ignition i use the common app tasker,
    it sleep (no bios screen or boot or s3 stuff ;-)
    just work
    more info about configuration pro and cons at:
    http://www.mp3car.com/show-off-your-...t-version.html
    i reply at your consideration because i try the pc hw and tablet hw
    and i remove from car a lot of wires
    it's a work in progress but not impossible
    May 2012
    Hi,
    right now I am deciding on whether to use a tablet or a real car pc.
    I too want fm radio, so I looked for tablets with integrated fm radio.
    So far, I found a couple of fm capable tabelts on alibaba, and I got prices for two:
    http://szrico.en.alibaba.com/product...time&edm_ver=e - USD140
    http://essential.en.alibaba.com/prod...Card_slot.html - 138 Dollar + shipping
    and there is one from ZTE:
    http://www.coolsmartphone.com/2012/0...goes-official/ which has a higher resolution and stronger cpu ~290 Euro.
    However I am not sure about the fm qualitiy. Yesterday I attached my Samsung Galaxy S9 to my car antenna. The reception was maixmal fair... My original car radio has a better reception and its reception is not very good.
    So for now I am rather back to the car pc, than the tablet. Just because of the fm radio issue...
    Cheers Christian
    May 2012
    And one thing I forgot...
    About the bluetooth hands free talking. At least in germany it is possible to get so called ultra sim cards (not twin cards).
    They can be used at the same time and if a call is coming in, both devices holding the sim card will ring, so you can pick up the call on either device.
    That would be a way for me to use as a workaround for bluetooth hands free calling.
    Christian
    May 2009
    Hampshire, England
    Thanks for the help guys! Looks like I got a lot more research to do! I think I have gone off the computer idea, mainly because of the touch screens.
    I am also looking into the O2 Joggler running Ubuntu, my friend has just ordered one for car use so I'm going to look at that.
    Car: Ford Focus
  1. Car Controls to android tablet
    By ViperThreat in forum Android Tablet
    Last Post: 12-04-2011, 06:41 PM
  2. Android Tablet 3.5mm to 5 channel amp?
    By glarior in forum Car Audio
    Last Post: 08-22-2011, 10:14 PM
  3. Any ideas about this android tablet?
    By brenda in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 08-17-2011, 12:22 AM
  4. Android tablet or Netbook. Which to get
    By jjohnston in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-17-2011, 08:24 AM
  5. Android Tablet
    By SLimp3car in forum Software & Software Development
    Last Post: 08-10-2010, 12:36 PM
Tags for this Thread
