Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Possible: Visteon/Directed controlled by Android?
  1. #11
    MySQL Error
    Oct 2004
    you could control it over Ethernet....
    all you need is a little hardware...Ethernet to serial, well.. the tricky part of this is DTR and RTS control
    then you could forget the whole usb thing
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Quote Originally Posted by spadival View Post
    Prolific also provide free Android drivers http://www.prolific.com.tw/US/ShowPr...id=230&pcid=41 .. though I haven't used it. I have modified Ksksue's driver to work with both FTDI and Prolific chips. I will host it somewhere if anyone needs it.
    I would like to have it. Mostly so if I encounter someone that will build something at least I won't have to go searching.
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  3. #13
    Variable Bitrate daclothe's Avatar
    Dec 2004
    Quote Originally Posted by jmullan99 View Post
    One problem for car use is that OTG host mode doesn't necessarily allow of charging AND using host mode depending on the tablet. Galaxy Tab 2 does not.
    timur has otg + charging working for the nexus 7 crowd. that's actually where that video came from (his thread on rootz)
  4. #14
    Jun 2007
    Since it is a small java file, I have attached the FTDI/PL2303 Driver file as a text file to this post.
    Attached Files Attached Files
  5. #15
    Jun 2007
    If you need serial or i2c connection, you can avoid host mode altogether with FT311D chip http://www.ftdichip.com/Android.htm . However, it hasn't quite caught on.
  6. #16
    Feb 2009
    Just a followup note. I have attempted to contact tuffbob (poster of the YouTube video) and no reply. Would be nice if he would at least respond. However, it's only been a week so we'll see.
    I'm thinking at this point that FTDI driver or not, in the end it must create a serial port object in Android and communication happens with that serial port. So to get over the OTG + Charging a Bluetooth serial adapter may also work.
    My research continues. If I know I can get reliable serial communication with the radio, I may actually attempt to make something in the way of an app (pretty green at Android development).
    03 Cadillac CTS
  7. #17
    Variable Bitrate Deric's Avatar
    Sep 2006
    You could probably use an IOIO board. The cool thing about the IOIO is that it supports USB or Bluetooth. For Bluetooth you just connect a BT dongle to the USB port of the IOIO.
  1. Mounting Directed/Visteon box
    By jmullan99 in forum OpenMobile
    Last Post: 07-18-2010, 03:16 PM
  2. Visteon HDZ300 V Directed DMHD1000 and Mitch Who?
    By Larzfromarz in forum Car Audio
    Last Post: 10-21-2009, 01:55 AM
  3. Does Directed/Visteon HD Radio work in the UK?
    By NibbleIT in forum General Hardware Discussion
    Last Post: 07-04-2009, 11:38 AM
  4. WTB: Visteon HDZ300 or Directed DMHD1000
    By LiquidKernel in forum Classifieds
    Last Post: 04-06-2009, 05:51 PM
  5. Visteon/Directed Board Size?
    By Deric in forum General Hardware Discussion
    Last Post: 01-25-2009, 07:44 AM
