Results 1 to 10 of 20
Thread: megane cc samsung tablet install
    Low Bitrate coolcoupe's Avatar
    Mar 2007
    lancashire ,England
    so after fitting a double din in my megy cc I have decided it does not work just as good as i wanted so its coming out and being sold and its being replaced by an incar pc using a samsung tablet 2
    it will turn on and off with the ignition and the music will also start and stop saving the place it end ,so far on testing it starts very quickly (much quicker than the radio i fitted)
    it will launch an app called car home which is a very basic front end which displays sat nav ,music and what ever else I want
    so fingers crossed it should work better than the double din i fitted
    ok so far all the apps are download to my tablet taskers is working as i want it powers up and loads a few apps when power is connected and powers down when screen goes black
    also i have started to make custom fittings for it i started by using the box it came in to get the size
    then covered in it tinfoil and used cooking oil to give it a non stick surface,and covered it in fiberglass
    then i trimmed it down
    next will be a test fitting then a light coat of filler and a good sanding down,
    Mar 2007
    lancashire ,England
    http://www.ebay.co.uk/itm/1108477567...84.m1439.l2649
    ok this is on order ready for touque app
    Mar 2007
    lancashire ,England
    Quote Originally Posted by coolcoupe View Post
    its here and works a treat
    Mar 2007
    lancashire ,England
    so first fiber glass mold did not work right so here is atempt 2
    its a ply frame then glue into place
    still loads to do yet :
    May 2012
    Nice.
    Sep 2012
    Yes very nice.
    I have megane 2 (not cc) and i'm looking to integrate nexus 7 so i follow your work closer
    Mar 2007
    lancashire ,England
    are you leaving it in the car or taking it out at night
    Sep 2012
    I take it out because i use them at work and at home.
    I'm thinking about relocate ventilation controls and put tablet under aeration. But no enough space to do this.
    Mar 2007
    lancashire ,England
    it is very hard to make it so that the tablet comes out , I wish I had decided to fit it in for good
    Sep 2012
    Yes i see but i'm thinking about robotic system to take tablet out.
    Do you progress on your ?
  1. Replies: 90
    Last Post: 01-27-2013, 04:58 PM
  2. Replies: 44
    Last Post: 09-23-2012, 08:28 PM
  3. Samsung Galaxy Tab 2 7inch tablet in 2006 G35 double din
    By viceversa in forum Android Tablet
    Last Post: 07-20-2012, 02:28 PM
  4. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 09:54 PM
  5. New Samsung Tablet PC
    By Evilbunny1114 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 05-02-2006, 11:18 PM
