Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Introducton and Samsung Tab into a 206 Range Rover Sport
  1. #11
    Sep 2012
    Quote Originally Posted by shadoguardian View Post
    Guyzer,
    Yea I've installed a lot of those rearview mirror monitors. I find those better than the in dash solutions since as you said, you only have to look in one spot.
    I realized that in the uk calling is enabled after I posted. Unfortunately in the us it's disabled which doesn't make sense because texting is enabled and we get an actual phone number for the tablet. Then I was thinking of using my google number as my main number but the issues with that is what if I'm in a dead zone and mms messages don't work.
    Heat is a major problem for me too. It's not even hot here where I'm at right now (50f) and my tab gets hot! I was hoping the tab 2 wouldn't be as bad since I have a problem with lag. My setup is temporary which consists of a cheap car mount that I got off eBay. I disassembled it and mounted it onto a bracket that i fabbed out of mdf board. I painted it with bed liner and attached it to my dash with industrial Velcro. It looks pretty good and is removable although I do need to spray another coat of paint. I'll snap a pick in a few days since I'm out of town cuz my wife just had surgery.
    I also found that the battery in the tablet drains faster than it can charge when I'm streaming music over Bluetooth and using navigation with the screen brightness on max. I'll have to see where the screen has to be to offset the discharge if that'll help. That reminds me, I need to get anti glare screen protectors when I get the tab 2.
    Your option number three is possible by doing what I did. You could paint yours silver to match you dash.
    ssschultz,
    Thanks for reminding me about iheart radio. I forgot about that one. I knew I forgot one and it was buggin me. Lol
    You may be able to use tasker to disable it. The option is keygaurd. I wasn't able to get it to work though. I only tried it when I was on gingerbread. Now that I'm on cm9 ics, I just disabled it full time since I don't have that issue with someone else touching it.
    Guyzer,
    hah just read how your going a different route now after a typed all of that. Lol oh well. I'll have to look into the mimics thing though.
    Looking forward to seeing some photos
    Sent from my HTC One X using Tapatalk 2
  2. #12
    Low Bitrate coolcoupe's Avatar
    Mar 2007
    lancashire ,England
    Quote Originally Posted by Guyzer73 View Post
    Correct :thumbsup: , was at Samsung just now and here's the proof:
    Cheers
    Guy
    looks same as mine i am gutted mine does not have sim slot
  3. #13
    Oct 2012
    Muscat, Oman
    Coolcoupe, I couldn't agree more I don't underdstand why they don't offer both versions worldwide, even though I don't want one without SIM card, you can't get those in OMan, only with SIM....
    Shadoguardian, I think going to go step by step. Firstly, something along the lines of option 3 using the vehicle dock to power and get audio out (I tried using the S3 but it's just too small and far away), plus BT for phone and ODB2 stuff.
    Then if I like the functionality I'll consider either going down the MimicsX2 with the S3 or the more complicated physical install with the Tab. However, I'm tending towards using the S3 and mimics whilst not as "cool" as doing a full install with a Tab it should provide the similar functionality and completely uninstallable if I sell the car in the future...
    Cheers
    Guy
  4. #14
    Oct 2012
    Muscat, Oman
    ok guys, it's been a while since I've been on here, and I've made a little progress in the time available after moving house...
    So I've now decided after using the Tab for about a month that I want to install it, rather than using the MimicsX2 solution. The reason for this is I can "bring" the Tab closer to the driver than the OEM screen and even with the build costs, it'll be cheaper than the Mimics route as I don't need to purchase a GVIF unit, or Mimics units to make it work as I'll use a deconstructed desktop dock wired into power and Aux audio, with an inline amplifier possibly, plus the build costs...
    So the plan is quite simple to construct a “Console” including the deconstructed desktop dock and install
    The actual installation of the Tab is what is actually where I need to make a decision as I currently have 3 basic options:
    1. To slide the Tab in from the side (or top) of the Console.
    2. To use magnets to secure the Tab in the console.
    3. To have some sort of tray that is hinged and allows the Tab to be slid into it.
    I’ve decided on Option 3 as the tidiest and most OEM version. However, and then you’re talking linear actuators to make it look smart, or mechanical push to open/ push to close locks used in the likes of kitchen drawers etc… I’m also considering using a push to open/ lock catch in combination with one, or two, RC car suspension dampers acting as hydraulic linear dampers. What do you think??
    Below is a sketch I made of Option 1, however, it gives you the general idea of how it should look when finished, albeit with some changes, but, the overall profile should be roughly maintained.
    I also made a very crude mock-up out of cardboard of option 2 which you can see in the photos below. Lots of things wrong with it; including: it’s too big; it’s sitting on the console rather than being incorporated and the profile it too “square.” But at least it shows that it’s doable and shouldn’t if finished well look to out of place.
    Now I’m currently creating a “stencil” in 1:1 scale for my local AM garage to try their hand at forming 1mm aluminium sheet for the hinged housing of the Tab. If this is successful then the idea will be to manufacture the entire console from aluminium and finish it accordingly. I’ll make a paper card version as well to develop the design further whilst they try and make the real thing.
    To stop the tinny sound of a hollow metal enclosure the voids will be filled with heat resistant expanding foam and, or, sound deadening material.
    That’s all for now folks, hope you all have a Merry Christmas and festive season.
    Cheers
    Guy
  5. #15
    Feb 2012
    This could come out very nice. Look forward to updates.
    Sent from my Galaxy Nexus using Tapatalk 2
  1. 07 Range Rover Sport carpc completed
    By genz in forum Show off your project
    Last Post: 05-02-2011, 10:37 AM
  2. 2007 Range Rover Sport EEEPC install
    By chronoguy in forum Show off your project
    Last Post: 06-24-2010, 05:26 PM
  3. New setup for Range Rover Sport
    By Murdered_Out in forum General MP3Car Discussion
    Last Post: 11-27-2008, 10:59 PM
  4. 2006 Range Rover Sport carpc
    By groovyx in forum Show off your project
    Last Post: 11-06-2008, 09:44 PM
  5. Range Rover CarPC - for all Range owners
    By RoyN in forum General MP3Car Discussion
    Last Post: 12-14-2005, 10:08 PM
