Results 1 to 6 of 6
Thread: taskers screen lock
    Low Bitrate coolcoupe's Avatar
    Mar 2007
    lancashire ,England
    taskers screen lock
    I am using taskers to start and end my tablet on power on/off ,but can taskers be used to lock the tablet if the headphone is unplugged or the power unplugged bearing in mind that the system will have shut down on power of .
    I want it to be extra security so that when the car is parked and the screen is black (the tablet will not be turned off just the screen) I need the tablet to detect movement or phono unplugged and lock the tablet if this makes sense
    any help would be great
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by coolcoupe View Post
    Yes. I am doing this currently only I keep my tab always on. I use Snuko for security so when I timeout my screen I launch the Snuko lock. I do the same when I wake my display up.
    Sent from my DROID BIONIC using Tapatalk 2
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Mar 2007
    lancashire ,England
    ok I have sussed out out to activate the screen lock when the headphone is unplugged (stolen) ,but how can i make the screen go blank(black) when the ignition is turned off without the screen lock as I dont want to to have to tap the code in every time i start the car ,my tablet is a samsung galaxy tab2
    Dec 2007
    AZ
    How do you have your tab connected? Not sure how you have it connected for ignition events but you should be able to configure a task to timeout the display based on the event.
    Old Proj II
    Old Proj I
    Mar 2007
    lancashire ,England
    its conected via a cigerate lights I can time out the screen after 7seconds but I want it instantly
    Constant Bitrate daclothe's Avatar
    Dec 2004
    there's a difference between the screen timeout and screen lock. you can toggle the screen off in addition to setting a low screen timeout value, but the only thing to consider is if you have tasker toggle the screen off first and THEN have any events that wake the screen you will end up with a sequence of 'on off on (wait 7 seconds) off' which is kind of silly.
  1. taskers help for noob (mega numb)
    By coolcoupe in forum Android Tablet
    Last Post: 09-23-2012, 10:08 AM
  2. GPS causes RR to lock up
    By Mustronic in forum Road Runner
    Last Post: 06-29-2010, 04:06 AM
  3. screen lock bypass?
    By henrybui in forum Road Runner
    Last Post: 01-16-2010, 05:21 AM
  4. W3bLock - Screen Lock w/ GPS Tracking
    By W3bMa5t3r in forum RR Plugins
    Last Post: 07-17-2008, 08:09 AM
  5. Not getting lock?
    By Misanthro in forum GPS
    Last Post: 12-23-2003, 01:21 PM
