You should read the XDA thread. I also own a Nexus 7 and I've seen "3.1 amp" power adapters not work because they are complete junk. This one is confirmed to work.
1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
You can have a great charger, but it won't do what you want it to do unless you also get a heavy duty cable. One that's thick enough and short enough to carry the current required by the tablet. So the moral of the story is... find the highest quality cable you got (a stock HTC cable works great... or even the one that came with the tablet) and try charging it again.
Current Setup
Nexus 7 Tablet
Built in head unit
Brutus 1500Watt Amp
Two Boston 12" subs
2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
Just because the charger is 3.1A does not mean that that is what it is consuming.
Maybe your tablet is consuming more than his...
Or maybe its battery is worn.
PS - I love the amazon comment Charging will be automatically stop when battery is full. Der! Why even bother mentioning that - it has nothing to do with the charger!
I'm using this USB ROM on my Nexus 7 install with no charging issues. You can enable fast charge and it automatically goes to sleep and enables airplane mode when you turn off the vehicle (as long as that also turns off the power source to the tablet)
http://mehrvarz.github.io/nexus-7-usbrom/
