Results 1 to 4 of 4
Thread: Tasker won't kill jetAudio
    Newbie focused313's Avatar
    Jul 2012
    Michigan
    I have an acer a100 running android ics. I am not rooted.
    I have tasker profiles set to decrease brightness, shut off display in 7 seconds, and kill bluetooth/wifi when the power goes off; all of those work. I had an issue with jetaudio not dimming the screen, but i saw that I had the override activated, so I fixed that. Now my only problem is that when I have a song playing in jetaudio with the interface open, even when the tablet loses power, it will continue playing, even though I set tasker to kill jet audio.
    Any ideas?
    Oct 2007
    American Fork, Utah, United States
    there is a plugin for tasker called taskkill. should do what you need
    Sep 2009
    +1 for taskkill as a good app: https://play.google.com/store/apps/d...taskkill&hl=en
    however, did you try the tasker media buttons command (stop or pause)? i never had it work correctly without checking the "use root" option though, so if you don't have root they probably won't help. they worked well for me prior to android 4.2.2, but then i had problems with pandora starting up again a while after pause. using a shell command to send the pause keyevent instead seems to work reliably though.
    Jul 2012
    Michigan
    thanks for the tasker killapp plugin, I tried that and it worked.
  1. Kill Switch...because I believe in over kill.
    By DracoPCGuy in forum Newbie
    Last Post: 04-17-2013, 07:15 PM
  2. Please post your tasker profiles...
    By Miata25 in forum Android Tablet
    Last Post: 01-25-2013, 04:02 PM
  3. Tasker Help
    By sk8rcj in forum Android Tablet
    Last Post: 11-02-2012, 12:06 PM
  4. Replies: 35
    Last Post: 03-10-2011, 05:17 PM
  5. WinAmp alternate, jetAudio 6
    By Rith in forum Software & Software Development
    Last Post: 07-26-2004, 04:21 PM
