Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: How to awaken/turn on Nexus 7 without using the power button?
  1. #11
    Constant Bitrate Lankin's Avatar
    Jun 2009
    Quote Originally Posted by treetop777 View Post
    Indeed OP from power-off there is nothing that will power-on the tablet except the actual power button. Tasker will only turn a screen back on NOT power-on the tablet. I'm in the planing stage of a tablet install and I'm debating whether to fab the tab into the dash in a way that i can remove it or hack the power button to extend it to an external button.
    Won't start install till summer but in the mean time I'll be keeping an eye on this tread.
    ^NOT TRUE^
    As was stated previously in this thread
    I found a possible solution... You can change the bios settings to turn the tablet on whenever it sees power. I'll try it out sometime this week and report back.
    http://www.gencoupe.com/diy-do-yours...-required.html
    EDIT: This worked perfectly. Unlock your bootloader and type "fastboot oem off-mode-charge 0". Now, even if the tablet is completely turned off, when you apply power it automatically boots to the home screen. No power button needed ever again.
    I have also used this solution to automatically turn on my nexus 7 once the tablet receives power.
  2. #12
    Jun 2011
    You can look for custom roms and kernels that incorporate knock2awake or swipe2awake
    Sent from my SM-N900T using Tapatalk
  3. #13
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    you can check ebay, I have found 30000 mah batteries with usb in and usb out, one side you plug in a charger , other side you plug in the tablet, then you can configure tasker to turn on the screen/gps/wifi etc etc when your phone is detected through bluetooth
    ebay object nr: 121209336215
    View my worklog here
  1. Best way to power a Nexus 7 and USB hub?
    By z3n in forum General Hardware Discussion
    Last Post: 06-04-2013, 03:44 PM
  2. Replies: 23
    Last Post: 12-26-2007, 06:54 AM
  3. Any way to turn CF's back button into...
    By Tidder in forum Centrafuse
    Last Post: 09-06-2006, 04:37 PM
  4. Replies: 55
    Last Post: 08-27-2005, 10:40 PM
  5. Replies: 3
    Last Post: 08-20-2004, 09:42 AM
