Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: LG G Pad 8.3 build/design process with many questions.
    Jan 2012
    I just ordered an LG G Pad 8.3 to perma mount into my car. The car is a 2005 VW Passat GLX Wagon. I'm planning to root it and use a stock version of Android 4.4.
    Now I had some questions that maybe you guys would have some answers or solutions for me. The big thing I'm wondering is I want to setup the tablet so that it doesn't lock when power is supplied to it (through a relayed power connection) so that it stays on and doesn't lock or turn off the screen. But once the vehicle is off and the relay removes power to the tablet I want it to power off the screen and stay powered on via it's battery so that it can perform syncing services in the background like syncing my music collection from the house. I'm just curious if there is a way to achieve this?
    Eventually things will get pretty crazy with this build, I've got a USB to I2S adapter which is going to feed a MiniSHARC from MiniDSP and then a high end dac with some other custom stuff. But for now I'm just going to focus on getting this to work the way I want. I was originally going to use an Odroid and a screen but I really wanted a nice quality 8" screen and also a tablet started to look better as it has all the GPS sensors and what not built in unlike the Odroid.
    So I'm sure I'll have more questions as we move along. The tablet should be here tomorrow I believe and I still have to decide how I'm going to mount it. I'd really like to mold a pod into the top of my dash above the center console and try and make it look as stock as possible like it was supposed to be there, I have to take it and hold it up there and see if I can work that out though without it looking too abnormal.
    Jan 2012
    Ok, looks like Tasker and maybe Autosleeper might be able to handle most of this for me.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    The intelligent DC-DC converter on the mp3car.com store can be jumper selected to supply clean 5V output for your tablet, and will turn on and off with ignition. Also you can jumper select it to delay turning off after ignition is off for a configurable period of time, to charge the tablet's battery. I have had great results with them.
    Jan 2012
    Thanks I'll look into that.
    Here is where I'd like to put the tablet. I have to decide if it's too large here or not. I want to build a whole pod that looks like it's supposed to be part of the dash and blends in nicely (possibly permanently and then getting the whole dash vinyl wrapped) so it'd look somewhat like a newer cars infotainment system.
    Where the stock radio is I'm planning to put a volume/navigation knob and some quick nav buttons.
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Never too big!!!Name:  uploadfromtaptalk1397862392987.jpg
Size:  206.2 KB so long as you can still see the bonnet
    Jan 2012
    Well I'd rather not cover or modify the vents if I can help it. So I want to make sure it's not going to block the view much. It's in a VW Passat so you don't sit up as high as you do in what looks like a truck/van there lol.
    Nov 2011
    With mine i was fairly commited very early in the build...vent had to go...it does however make the other 3 work really well! Yours looks like it sit there really well tho.bit of fiberglass here and there...mabee just build a pod that attaches on top.or like mine just get a replacement center dash and go from there...its very easy to do it that way as you really dont need to dissasemble the car untill your done..its well worth the effort
    Jan 2012
    Yeah I want it up higher so I don't have to look away from the road so much and its in a more natural spot. This is why I ruled out the stock radio location.
    Nov 2011
    Agree...standard spot is not always quite right for a touch screen.i use mine for 4x4 mapping..any lower would be no good...higher would be better but that would be the pushing legal side too much
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    This summer i will install a tablet in my truck and have a Samsung tab3 8.0 setup and ready to go but i made a mistake and started playing with a GPad 8.3 - Amazing display! So i bought one. Excitement was short live though because when i started to fiddle with it for installation in the truck, i found i major flaw - OTG plus charging don't work and that's a must for me.
    Along those line i wanted to ask what would be you rational behind REMOVING power from the tab when the engine is shut down? I think - well, in my case - the tab would recharge more often when the car is sitting (garage, work) so i would think it would be better to supply power to the tablet when the engine is shut down. Unless you are scared to discharge the battery in the car..? is that it?
    BTW, my intentions is to power the tab all the time and the only thing that will go off and come on is the display.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  1. Replies: 6
    Last Post: 07-19-2013, 07:36 PM
  2. Carputer build, setup and design
    By stalkerstyle in forum Newbie
    Last Post: 02-02-2007, 11:27 PM
  3. Design and build a winner!
    By Xterrian in forum General Hardware Discussion
    Last Post: 05-29-2002, 06:17 AM
  4. My first design and build - need advice from you guys.
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-02-2002, 01:04 AM
