carputer: if i run out of storage, i get a new hard drive with a larger capacity, and either add it as a storage drive, or use one of the many drive swap programs to swap my os, and files over to the new, larger drive.
for ipad: i either need to get a larger model, assuming that there is one with more space available, or get a wireless hdd in my car to hold all that data, and then create a adhoc network. Or I can get the usb adapter, and a usb external drive(which can have their own special needs for getting
power).
correct me if i am wrong, but once the ipad is connected to a wireless media drive via a adhoc network, you wouldn't be able to connect to
wifi anywhere-- you would first have to disconnect from the hard drive, and then connect to the
wireless internet. what about using the 3g? are those separate connections, or can the ipad only use 1 at a time?
