Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: My iPad 3G install in a 2006 mustang.
  1. #11
    Jan 2008
    while i really haven't worked with, or even heard a setup with a 360, it should definitely not sound like crap. using a flat eq in the 360, your audio should sound close to stock.
    if you are using the eq on the ipad, turn it off, you can also try lowering the volume on the ipad to see if that changes the quality of the audio(or, if it is really low, raise the volume). the reason for this is that the ipad might be capable of a higher voltage output then the 360 can handle, or the ipad might be pushing its internal amp too hard and also causing crummy audio to come out.
    another thing to check would be the programming on the 360--there might be some level adjustment that needs to be done.
    also, what are your gains on the amp(s) set to?
    just fyi: i ran a ipod/crossover/amp setup for 3 months that sounds only slightly worse then my current computer controlled setup-- but both were way better then the stock hu..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #12
    Jun 2010
    Quote Originally Posted by soundman98 View Post
    I set the amp gains all the way down as per the 360's instructions. I set the ipad eq. to none and that seemed to help quite a bit. Thanks again for all the help.
  3. #13
    Jan 2011
    looks great man
    awesome install man, i've been looking all over the internet trying to find a tutorial.
    have you posted one anywhere? i am really wanting to do this install in my 07 GT.
    thanks man
  1. Replies: 8
    Last Post: 06-29-2010, 06:24 PM
  2. iPad 3G security breach!
    By RipplingHurst in forum Apple iPad
    Last Post: 06-10-2010, 10:34 PM
  3. Mustang 1-DIN Indash Install
    By NOS TANG in forum Show off your project
    Last Post: 12-18-2004, 10:53 AM
