Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Thread: Control XMPCR/XMDirect with iPad?
  1. #21
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yes.
    Want to:
  2. #22
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    It would, but I don't know any programming stuff and I don't want to spend extra money and I don't want to have to hide an extra box.
    I have bad luck with vehicles...
  3. #23
    May 2008
    I got the breakout board and I started the soldering job today. Still need to figure out the program side of things though...
    Sent from my iPad using Tapatalk
  4. #24
    May 2008
    Got the cable built and tested. Couldn't figure out how to avoid the "Not Charging" message though... The serial interface works and the iPad does trickle charge... ( :cry: ) Now I just need to connect the XMPCR to my iPad and get some software going. YouTube video and pix to follow after I have had some sleep...
  5. #25
    May 2008
    Video of test
    You have to view it in 1080 if you want to read the text. Sorry. I'll remember that for next time.
  6. #26
    May 2008
    Next video. I have the XMPCR hooked into the iPad through the TTL lines. iPad's RX connected to the XMPCR's TX, and iPad's TX to XMPCR's RX. All I get is gibberish...
  7. #27
    May 2008
    Ok, I'm close to giving up on this. I have a screen-less Dell laptop that I could use in place of a Sheeva, plus it has a good battery on it. What do I need to do to make it do like Bugbyte was suggesting I do with the Sheeva?
  8. #28
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Does the XMPCR use the USB for audio? If so, it's probably better to use Windows for this.
    Basically, you want to have an app that will send the appropriate commands to the XM driver when you contact it. I was thinking that with the Sheeva a web server would serve up a page to the browser with buttons on it. PHP or something similar would send the commands to the driver. You would build a web page with buttons that trigger the commands.
    Want to:
  9. #29
    May 2008
    Quote Originally Posted by Bugbyte View Post
    No, the audio is a line out from the XMPCR. Since the Sheeva is $100, and I don't know PHP, I was thinking I could use this old laptop to control the XMPCR through my iPad.
  10. #30
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'll trade you a sheeva for your iPad.
    Tidder
    Try RevFE
  1. BMW E60 install and I-Bus retrofit....tricky
    By Craggy in forum General Hardware Discussion
    Last Post: 11-17-2010, 04:06 AM
  2. Up to 750GB external hard drive for the iPad
    By RipplingHurst in forum Apple iPad
    Last Post: 09-08-2010, 12:33 AM
  3. Climate Control
    By Cocide in forum Newbie
    Last Post: 07-02-2008, 11:58 PM
  4. The WinXPe Colab Installation instructions
    By darkslyde in forum WinNT Based
    Last Post: 02-17-2008, 05:59 PM
