Ok my setup is pretty basic for now. I have a custom built av cable for charging and audio output (of course the one you can buy from
apple will work but I built mine for free instead of paying $40) this av cable is run to the equalizer to give volume control (the iPad cannot control the volume if it goes through the dock port) as well as better tuning than the iPad presets. The eq has front rear and sub outputs run to my amplifiers. Not the best sounding setup by any means but it works. For better sq you will need a DAC such as the istreamer then run this to your eq. And for the best possible sq use the istreamer combined with a high end signal processor such as an audison bit one or bit ten or similar to those.
