Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: New Project....Dash Bezel
  1. #21
    Vendor - C&C CUSTOMS CabeSipes's Avatar
    Jul 2009
    Pretty much the tape is the easiest way. I usually put tape on the backside of the button holes and then body fill right over them. Then remove the tape while the body filler is still wet and use a toothpick or q tip to push the excess thru the hole and clean up the edges as much as possible. Then once its dry sand down smooth and spend that extra 20 min. "fine" sanding around the holes. Usually a peice of sandpaper wrapped around a pencil will let you get the inside edges of the holes pretty good.
    Google my name if you need to know who I am.
  2. #22
    Dec 2009
    Thanks, I'll try that !
  1. Project Red Alert: 1994 Customized Camaro CarPC v3
    By meissenation in forum Show off your project
    Last Post: 07-15-2008, 06:23 AM
  2. dash bezel on 07' bmw 525
    By mxxmikexx in forum General MP3Car Discussion
    Last Post: 04-11-2007, 12:22 AM
  3. Should I remove LCD from casing or use the bezel?
    By xraycat in forum Fabrication
    Last Post: 03-31-2007, 01:00 PM
  4. Fiberglassing over a vinyl dash
    By tml240 in forum Fabrication
    Last Post: 08-30-2006, 01:19 AM
  5. WTB: 7" Lilliput project housing/front bezel
    By kamikaze2112 in forum Classified Archive
    Last Post: 09-28-2005, 05:58 PM
