Results 1 to 7 of 7
Thread: EEEPC 1000 and touch screen
    Low Bitrate Juliemac's Avatar
    Upstate NY
    I bought a 8" LCD with touch screen from Dynamix and loaded the drivers.
    I can get the PC to release control of the mouse to the touch screen to calibrate or use.
    Any ideas?
    1981 VW Scirocco, 2L 16v turbo. EEEPC 1000 running Mega Squirt and music.
    Http://www.menloparkrandd.com/scirocco
    Elsewhere
    It doesn't "release control of the mouse".
    You can have the mouse and the touchscreen together.
    How about the Wiki?
    Upstate NY
    Ok. Then its got to be in the calibration software. It is supposed to show x's in the 4 corners, but the first runs for 5-10 secs then stops and you cant get the touch screen to respond.
    Elsewhere
    How about the Wiki?
    Upstate NY
    Ok. Trying that in a few secs. DLing it to the pc now. Then back out to the garage....
    Upstate NY
    Ok. I uninstalled the old software, rebooted and installed the new.
    rebooted (just to be safe) and plugged in the touch screen. It detected the controller.
    when I touch the screen I can drag the cursor, but releasing sets the cursor back to the top right quadrant of the screen.
    If I try to set the 4 point, the x blinks 4 times and stops dead.
    I checked the PC mouse to see if it had some weird setting, but it looks right.
    Any ideas? This is getting frustrating....
    Upstate NY
    Ok. I found that the case has warped a bit and was touching the screen. THAT reset the cursor.
    Opened the case, heated and bent it back and VOILA!
    Works perfectly!
    The newer software is much better thanks!
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
  3. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
