Updates to Copy In Order
Download Copy In Order
What is Copy In Order?
This is a program for copying files and folders in alphabetical order. Windows rarely copies files or folders in the order you would expect. And normally this isn't a problem. But, on a flash-based MP3 player, the device may very well play the songs in the order they were copied, instead of alphabetically, or by track info. This program allows you to specify a source path (or paths), a destination path, and a file-type to copy. Then, either click COPY FILES and wait patiently, or click WRITE BAT, which will write out a .BAT file with all of the MKDIR commands, COPY commands, and DEL commands in it for reviewing/editing/running. The program has an option to overwrite existing files, and an option to remove files from the destination which no longer exist in the source.
What are the requirements?
Windows XP or later, .Net Framework 2.0
