Results 1 to 5 of 5
Thread: Updates to Auto dimmer
    Dec 2010
    Download Auto dimmer
    What is Auto dimmer?
    This program locates the position of the sun from your position and dim the monitor if its dark.
    Also you have a manual mode and a autorun setting.
    Screenshots
    Dec 2010
    Bug Fixes in version 1.1
    custom brightness can be set (20%-50%)
    Now the Timezone will be considered (please set this in dimmer.ini on utc=)
    If Centrafuse or other programs change the Brightness, dimmer change it back again
    All settings like brightness and the last active mode will be saved on exit
    more stable
    description update to:
    You just have to set the latitude and longitude in the dimmer.ini
    If you don't know how to find it use this site: http://itouchmap.com/latlong.html
    Dec 2010
    New features in version 1.1
    Automatically dims your monitor depending on your position
    A 20% - 50% Dim value can be set
    Autorun setting
    Manual and auto mode
    Works perfect with Centrafuse and other Front Ends
    Overwrites brightness value if any other prgram change the brightness (Centrafuse for example)
    Latitude/Longitude and UTC timezone must be set in dimmer.ini
    Dec 2010
    -Latitude/Longitude and UTC timezone must be set in dimmer.ini
    -Overwrites brightness value if any other prgram change the brightness (Centrafuse for example)
    -Works perfect with Centrafuse and other Front Ends
    -Manual and auto mode
    -Autorun setting
    -A 20% - 50% Dim value can be set
    -Automatically dims your monitor depending on your position
    Dec 2010
    Bug Fixes in version 1.2
    Solved hibernation problems, because path to ini file lost
    ini file now automatically created if it not exists
    support update to:
    http://www.mp3car.com/vbulletin/software-software-development/146117-auto-dimmer-lon-lat-position.html#post1430095
    version update to:
    1.2
  1. Auto dimmer (with GPS or LON/LAT position)
    By schreda in forum Software & Software Development
    Last Post: 08-20-2013, 05:53 AM
  2. Updates to Centrafuse Auto - North America
    By raygun in forum Auto App Mart
    Last Post: 08-04-2010, 03:47 PM
  3. Updates to Centrafuse Auto Standard Edition
  4. Updates to Centrafuse Auto (30-day Free Trial)
    Last Post: 08-04-2010, 03:46 PM
  5. Auto Dimmer
    By efun in forum Road Runner
    Last Post: 05-29-2009, 11:56 AM
