do you get an error? or just crash to the desktop?
"If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
Albert Einstein
heh, now I cant run AP at all... When it tries to start up winamp (along with the actual Autoplay software. It crashes.... with an error:
WINAMP
WINAMP caused an invalid page fault in module KERNEL32.DLL at 016kbff644df ....
My hardware is:
Shuttle SV25
with Nvidia GF4 MX420 PCI graphics....
Regards
Richard
Albert Einstein
ugh.... sounds like your OS is a bit dodgy..... can you run winamp on its own??? It really sounds like winamp is faulting on a bad kernel32.dll (possibly a corrupt copy?)
I run my software in windows98 in the car and of course it works fineone thing to note, in doing the whole 'cutdown' 98lite windows, you MUST have the 'Active Movie' component installed in windows98 otherwise video playback will not load, and will most likely crash with a runtime error (this is what I got anyway)..... that may explain your original problem....
Project - GAME OVER :(
aahhh.. super
I got a runtime error earlier .. thats correct...
It prob. just my OS that craps it up...
Ill reinstall it now.. and a little off topic.. does anyone know if the Windows98SE supports hibernation?
Regards
Richard
Albert Einstein
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
correct.... but the word you are looking for is 'standby'... hibernation differs from the fact that its a software based 'standby' by dumping the contents of RAM to your HDD...
t0ffluss let us know if your problems were solved![]()
yup .. my problem was solved.. reinstalled WindowsXP .. works like a charm ...
anyway...
why is it, that.. when I put my computer into hibernation ... (and autoplay is running) craps out when resuming from hibernation?
wich mode to use? ... hibernation or standby ?
hibernation = no power usage <-- am I right?
standby = how much power usage... considering its a VIA800Mhz ? roughly ...
Best Regards
Richard
NORWAY
Albert Einstein
and btw... in windows XP ...
trying to run DivX
get error:
Run-Time Error '6'
Overflow
what gives?
Regards
Richard
Albert Einstein
I know this is a fairly old thread BUT..
What componant is this part of as I cant see it in the windows add / remove menu?
And i am recieving the same 'runtime error 6 overflow' error with the latest version of AP, I have just rebuilt the machine and presume it is this that i am missing.
Audio:Pioneer KEH P6900R, CD multi Changer, CD-RB20 Aux input adapter.
System:AMD550, 192 Ram, 13Gb HDD, Via Micro ATX, o/b Sound, 32Mb G/c, T/screen In-Dash 7" LCD VGA, IrMan, 120w inverter.
O/s:Windows 98lite
Software:MediaEngine 1.7.7
