Results 11 to 20 of 25
Thread: am I missing something??
  1. #11
    Feb 2003
    Rayville, LA
    Can I skip this step, since I'm not using IRman or a remote?
    Next step is to register the supplied mscomm32.ocx run-time library - used for serial port IRman access within your operating system. This can be achieved through one of two supplied batch files, install_lib9x.bat for windows 95/98/ME and install_libNT.bat for windows NT/2000/XP. If the batch file(s) fail, you may need to edit their command syntax to work with your target machine. Also if not already present on your system, grab a copy of the Visual Basic 6 runtime files from Microsoft to install at this time.
    Cordell
  2. #12
    Feb 2003
    Rayville, LA
    I got everything configured now. Just when I go to run autoplay.exe it gives a run-Time Error '5'. Think it has anything to do with VB6? I downloaded it, but I dunno where it installed to. Does it have to be in the same folder as autoplay??
    thanks
    Cordell
  3. #13
    Feb 2003
    Rayville, LA
    don't mind me multiposting.. I'm just ignorant and figure things out as I post them on the forum.. guess this is a way to make clear my problem to myself.. so then I can figure it out.. haha!
    *noob*
    Cordell
  4. #14
    Jan 2003
    Ruston, LA
    YES, just configure the keyboard.
  5. #15
    Jan 2003
    Ruston, LA
    thanks
    have you configured playlist.ini and ran playlistbuild.exe ?
  6. #16
    Feb 2003
    Rayville, LA
    Yep I set the two folder paths correctly.. e:\mymusic and e:\playlists .. and then I hit Build and it said it did it successfully. I'll play with it tonight.. it's probably something I'm doing wrong.. usually is lol
    Cordell
  7. #17
    Feb 2003
    Rayville, LA
    did the keyboard config also.. same
    Cordell
  8. #18
    Sep 2002
    Just North of Toronto, Ontario, Canada
    when you say you downloaded VB6, did you mean the runtime? heres the link from magnetiks website for the runtime:
    http://www.microsoft.com/downloads/r...top&ordinal=23
    just run the installer and it should install it for you. Do you have directX installed? grab DirectX 8.1 from here:
    http://www.oldversion.com/program.php?n=directx
    it isnt nearly as big as DirectX 9, and should work just fine.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
  9. #19
    Feb 2003
    Rayville, LA
    Yep, that's what I downloaded. Got it straight from his site as well. Does it matter where I installed it to? I have DirectX9.. that should work with it huh?
    Cordell
  10. #20
    Sep 2002
    i dont think it matters where it installs to, i think it just installs it into windows.
    yeah, dx9 should work, maybe magnetik would know more about this.
