Oh yeah! just to add to the above>>> the previous version of Autoplay work fine on the incar 98 lite box and the win2000 laptop!
so if anyone knows of owt esle that might have caused this change then I would be greatful to hear the solution! Cheers,
Has anyone else come accross this error?? how can i fix it??
On starting the latest version of autoplay on my incar box (win98 lite) and my laptop (win 2000 pro) i get the following error:
Runtime-error
'-2005532292 (8876017c)':
Automation error
However! i have taken this setup from my home pc (win xp pro)where i have been setting up the software to my spec and this works fine no error!
As far as i can see i have installed everything needed!
Audio:Pioneer KEH P6900R, CD multi Changer, CD-RB20 Aux input adapter.
System:AMD550, 192 Ram, 13Gb HDD, Via Micro ATX, o/b Sound, 32Mb G/c, T/screen In-Dash 7" LCD VGA, IrMan, 120w inverter.
O/s:Windows 98lite
Software:MediaEngine 1.7.7
O/s:Windows 98lite
do you have direct X installled?
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
I have uninstalled everything related to Autoplay to start from ground level.
I downloaded the latest release of Autoplay and extracted to C:\Autoplay
Downloaded vbrun60sp5.exe and installed... no errors
Downloaded dxwebsetup.exe and installed... no errors
Downloaded DivX503Bundle.exe and installed... no errors
Ran install_libNT.bat completed successfully
Configured .ini's:
playlistpath = c:\autoplay\playlists\
videopath = c:\autoplay\divx\
mp3folder = c:\autoplay\mp3audio\
playlistfolder = c:\autoplay\playlists\
Populated the mp3audio and divx folders with media
Ran playlistbuild.exe ran succesfully
Ran Autoplay.exe
And still get the error:
Run-time error '-2005532293 (8876027c)':
Automation error
Any idea on this??? Love the software and really would like to get it to work!
Is there anything that i have missed out!
O/s:Windows 98lite
just replied to your email jakeep.....
well you say that the prior version works... the major change was DirectX GUI's.... so maybe that is the problem???
i noticed you used the dxwebsetup.exe, can you get hold of a full install of DX 8.1 - 9??? and try installing that. I have never used the DX9 websetup before, have always downloaded the full installers..
Project - GAME OVER :(
Yeah i had my reservations about that DirectX Setup myself as well! I'll give it a bash today with another earlier version.
O/s:Windows 98lite
Got another update for you if this helps.! Fingers crossed!
I have tried loading the DirectX 8.1 to see if that makes any difference but still the same error.
Also I have put the bogus playlist file name in and it gets to the point in the code where it checks for the playlist folder as I get the error message 'Unable to successfully load playlist files'.
And this is the same for the 98lite and the win2k set-up
Hope this sheds some light..
O/s:Windows 98lite
think I may be on to something with this problem!! have come across this on a web site:
DDERR_OUTOFVIDEOMEMORY 8876017c -2005532292 DirectDraw does not have enough memory to perform the operation.
Will follow it up!
However if anyone else has any info as how to rectify this..... dont be shy!
O/s:Windows 98lite
go Start>Run and type "dxdiag". this will load the directX diagnostic control panel. go to the Display or Graphics tab and run the DirectDraw tests to make sure DirectX is working.
ran the dxdiag tools and test and they ran succesfully.
Which doesnt help really! bugger cheers though worth a try.
Comming to the conclusion that its just a couple of turd on board graphics cards! unless anyone else has another idea?
Cheers for your help everybody!
O/s:Windows 98lite
