Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Blue Tooth dongle not active after being power off
    Jul 2004
    I'm having a problem with my bluetooth dongle. When the computer has been off and then powered back on, the bluetooth dongle is not active. I have to pull out the dongle from the usb port and reinsert it. Once I do that, the dongle is perfectly fine and active. If I reboot, same problem occurs.
    Other than that, it's the only problem that I have. Has anyone experienced this issue?
    Dwaine
    2003 Black Impala
    Feb 2005
    East Bay, Cali
    Search for Devcon
    This is a common problem with USB ports under Windows. Do a search on this forum for Devcon, which is a utility from MS that allows you to turn the USB port on after power down or hibernation. It is a little complicated, but the information on how to use this program is there.
    Cheers and good luck..
    Jul 2004
    Tried devcon. It did not work. The device just reloads and is not picking up the bluetooth interface. In the device manager, the device is working fine. But in the bluetooth manager, it's still looking for a bluetooth device to be attached.
    Pull out the bluetooth dongle, and put it back into the USB port. The bluetooth services are available.
    I do notice that when the bluetooth dongle is working, if I reboot the computer. The PC will pick up the dongle and it works perfectly. When the pc is shutdown by the DC-DC power supply, on power up. It's find the dongle, but it's not connected.
    It's a completed power off and shutdown.
    2003 Black Impala
    Mar 2007
    is your dongle connected to a USB hub? I find that certain usb devices work better when connected straight to the computer's USB input.
    Jul 2004
    I have pulled it into the pc usb connection, then the hub. I added a power adapter to the hub, because I though that it was not getting enough power.
    All the same results. I also applied the VIA usb filter patch.
    Same out come.....
    Tried the widcom drivers, when I discovered this problem.
    Then I tried the IVT drivers. Same issue.
    On reboots, it's ok if it's active. On power shutdowns, the device is listed as working. But it's disabled, the the little blue bluetooth logo is black and white.
    2003 Black Impala
    Mar 2007
    maybe trying a different dongle.. I found my belkin dongle works fine running of the PC.
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Try disabling power monitoring of your USB Root Hubs in Windows Device Manager...
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Dwaine, also make sure Device Manager isn't set to shut off the dongle. In Device Manager, right-click on the dongle, go to Properties, then the Power Management tab, and make sure the box for 'Allow the Computer to turn this device off to save power' is UNCHECKED.
    Jul 2004
    Quote Originally Posted by Nola111 View Post
    Thanks... I'll check it today and see if it makes a difference.
    2003 Black Impala
    May 2007
    Hm...
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. Finalizing Power Supply Options
    By Nstyle in forum Power Supplies
    Last Post: 04-01-2007, 04:40 PM
  3. ****Celica Carbon Fiber Car Computer Finished****
    By hombredelassrta in forum Show off your project
    Last Post: 09-02-2006, 03:22 PM
  4. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 11:58 AM
  5. Blue Power ButtoN?
    By Daven in forum General Hardware Discussion
    Last Post: 03-14-2005, 05:45 PM
