Do you have the option to pick up the phone?
When it passes the
sound to the computer, do you get a message on the phone saying "Answer on the phone Yes or No?" Why I am asking this is I noticed that if I chose "no" the gateway would then hold and NOT hang up at 3-5 seconds. This showed it is the way the phone handles the transfer. So, if you get this message, start your serial connection, then your Audio Gateway connect it manually. Even if it looks connected (mine did as well) once you have the Audio Gateway up, check the Audio Gateway signal strength to confirm it is actually connected. If you get the "Answer on the phone yadda yadda" hit no.
Click on
bluetooth places, view devices in range, (it will pick up your phone on the list, right mouse button in properties. This will show you what devices have access without asking for permission. Check off Audio Gateway and Serial Port.
Also, in the phone did you set it to always allow connection?
What phone do you have?
I finally fixed mine today, it was a
combination of upgrading the firmware on the phone and a few other things. Some of it was the set up above.
