Results 1 to 2 of 2
Thread: Bluetooth Problem
    May 2008
    Nassau, Bahamas
    Bluetooth Problem
    So i was having problems with my carpc. The pc kept crashing with a bluescreen of death and restarting. When i went into checking the issue, which i thought was hardware. I found out that the Bluetooth software was the problem of the crashing. So i disabled it. Anyone got an idea of a bluetooth update for windows 7? Should i update it and see what happens?
    Elsewhere
    I would look into a bluetooth stack from the manufacturer that is compatible w/ Win7 specifically.
    If you're running a manufacturer-supplied BT stack, you might consider removing that and using Windows' built-in BT stack.
    How about the Wiki?
  1. FAQ: Setup Bluetooth GPS and remove useless COM ports
    By pi3ch in forum The FAQ Emporium
    Last Post: 02-19-2010, 08:06 PM
  2. Bluetooth Serial Port Nightmare, IOGEAR, Zoom
    By matt621 in forum General Hardware Discussion
    Last Post: 07-05-2008, 07:55 PM
  3. a strange problem with bluetooth and K750i, please help!
    By HuseyinOzsut in forum Wireless Communications
    Last Post: 05-26-2008, 01:22 PM
  4. Please Help! Widcomm 4 Bluetooth problems...
    By shmartyn in forum Wireless Communications
    Last Post: 07-28-2007, 06:09 PM
