Results 1 to 3 of 3
Thread: Using your M2-atx computer power supply in a 24 volt marine / boat installation
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    I have a few questions about marine 24 volt systems. I thought the answers might be beneficial to others, so I will be posting both my questions and the answers here in this thread.
    • What is the spike /peak voltage that should be expected in a 24 volt marine or boat environment?
    • According to the spec sheet, clamping will occur at 25-27 volts. What is the exact failure behavior when input voltage exceeds 25-27 volts?
    • How long can the voltage exceed 25-27 volts before clamping occurs?
    • Is there more or less heat generated when operating in 24volts mode vs. 12 volts?
    • At what input voltage will permanent damage occur to the unit?
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by Fiberoptic View Post
    From the creator of the M2-atx:
    Quote Originally Posted by Andrei
    M2-ATX will work at 24V, but will not work with 24V b atteries (big difference, since 24V batteries are actually 28V)
    Try M2-ATX-HV, it can handle up to 32V (Actually will work up to 35V!)
    Jun 2008
    Trouble with boat pc
    I have been having trouble with the 5V rail shutting off when powering the pc on my boat. I am using one of the 12 volt leads on the power panel under the console. Should I be using a 24 Volt connection instead? The pc works sometimes and other times it won't boot. Thanks for any replies. Also, the battery draining circuitry seems to be specific for 12 V systems? How much will it drain a 24 V system before the circuitry will shut off?
    Marc
  1. ATX power supply question
    By dudah85 in forum Power Supplies
    Last Post: 10-10-2006, 05:49 PM
  2. ATX Motherboard... power supply questions
    By msreyes in forum General Hardware Discussion
    Last Post: 05-09-2006, 09:01 AM
  3. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. 12 V input ATX 250W Computer Power Supply
    By brondel in forum Classified Archive
    Last Post: 02-18-2003, 03:04 PM
Tags for this Thread
