Results 1 to 9 of 9
Thread: Moisture
    Newbie Teknoledgi's Avatar
    Jan 2005
    Gold Coast Australia
    Moisture
    I read a while back that you can get a special spray for electrical components like motherboards that protect it from salt spray and moisture.
    Anyone know where you can get this stuff
    Steve
    Lilliput 8" Touchscreen LCD
    VIA EPIA MII-12000
    60GB 3.5" Hard Drive 5400
    512MB DDR PC2700
    DVD Drive
    802.11G Internal Wireless Card - External 5db Antenna
    100m USB Bluetooth Adapter
    Nokia N70 Phone
    GPS USB Receiver
    Centrafuse 1.6
    May 2006
    Yeah, I would like to know that too if there is something like that.
    David
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    I've read about this stuff before ...
    I recommend you use "Stabilant" ...
    http://www.stabilant.com/appnt42h.htm
    The next step down from this product would probably ur average dielectric products that you find in automotive components.
    [ 5-spd 1996 M A X i M A SE ]
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    There's "conformal coating" that is applied to circuit boards used in industrial applications. You'd have to be careful not to get it on any connectors or sockets.
    I'd try to keep the enclosure sealed if possible; use a liquid cooling system for the CPU (if necessary) so the radiator can be outside the box. If heat in the case is still a problem, cool the case by wrapping a couple of sides in stainless tubing (brazed to the case) and circulating cool seawater through it.
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    We use conformal coating made by 3M on breath analyzers we ship to Florida. But when u spray it on, you cant get it on the connectors because it will give you a intermittent connection. But the stuff does work as we have tested it in are environmental chamber numerious times before we got are insturmants approved by the FDLE. But it does work, and if anyone wants more info on it, let me know, ill get more info for everyone.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
    Feb 2006
    More info would be great. I am starting to build stainless enclosures with a NEMA 4 seal for boat applications and would like to offer that spray as well.
    -Gordon
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    I found this link while searching for something else:
    http://www.marinecomp.com/seasafe.htm
    This company uses conformal coating plus something called a VCI (vapor corrosion inhibitor) which is material such as foam that emits a corrosion preventative.
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
    Sep 2006
    I also know of a company that does coformal coating, they do really good work and are fair priced. I would go with parylene for a conformal coating but there are a number of others such as silicon, epoxy, acrylic, polyurethane. My vote is parylene, nothing can get through it. Anyone need the info let me know
    Jul 2001
    I have used Lear chemical research corp's "corrosion block", results seem to be good right now but its still to early to tell. By next season I should know for sure if it was effective or not
  1. COOL carputer with AC?
    By eduardovdr in forum General Hardware Discussion
    Last Post: 01-28-2006, 07:54 PM
  2. Dry-joints and moisture: Prevention is better than cure.
    By JayKaye in forum General Hardware Discussion
    Last Post: 05-18-2004, 02:01 PM
  3. Condensation
    By slboytoy in forum General Hardware Discussion
    Last Post: 02-10-2004, 03:10 AM
  4. why do ppl think this doesnt work?
    By will2710 in forum General Hardware Discussion
    Last Post: 12-26-2000, 12:23 PM
