Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 61
Thread: Dooputer?
  1. #51
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    HAHAH id like to see that
    Brown 2010
  2. #52
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I wonder if that would just make fart noises if it got really wet
  3. #53
    Mar 2006
    NJ/RI
    well its a marine audio component...so it shouldnt fart too much....
    now it the jetski flipped...then maybe it might fart some...
    Brown 2010
  4. #54
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Thought id give my take on this
    You could use a PDA it would solve the touchscreen, space and waterproof issue (using a waterproof bag)
    You could also get a MII 6000E which is a 600mhz Fanless mini-itx which i use and submerge it in a air tight container of oil or as tight as u can without the oil spilling.
    A guy cools his pc totally in oil without any fans and thats a full motherboard
    so a mini-itx thats ment to run without fans would be cooled enough
    I use D3 frodoplayer and movies running at the same time on my MII 6000E with no problems at all so it's robust enough for the dooputer.
    And you can also get a old PDA and use that as your monitor
    If you use sidewindow installed on the PC it turns the PDA into a windows display so you can have frodoplayer or whatever running on the PDA screen and u can also use the PDA's touchscreen as the mouse with this software.
    Thats my take on how you could make a dooputer
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  5. #55
    Aug 2006
    Spring City, Tennessee
    if your still working with ideas for cooling, think along the lines of how the engine of the seadoo gets cooled. Its water, but no rad. Why? Who need a rad when you have a billion gallons of water cooled by the enviroment. Now the big issue here is coming up with components to survive that water.
  6. #56
    Apr 2005
    well, make sure the cointainer with oil has a heatsink of some sort, otherwise it'd be a waste
  7. #57
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    gadam I wish I could win the lottery
  8. #58
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Okay cooling is probably the biggest issue on this build. If the pc was sealed water tight. you could buy a water cooling system from http://www.water-cooling.com/ and run the water lines outside the water tight pc. Im sure you could get heat sinks for the hard drive, processor, memory, video card, etc.
    As for the oil filled pc...The one thing i remember from those is that the hard drive was not in the oil. I guess it wouldn't matter since the drive is probably air tight also. It may work. Using a small EPIA Via motherboard would probably be the best way to go.
    And as for the Bike Pc. I like that idea. Small 12volt battery (from child electric jeep). cheap Laptop. Small 5 inch touch screen or smaller. Maybe headphones for sound. Rear camera Possibly those generators that connect to the wheel. Funny sh#$ though, Last month i was driving to lunch and i saw some guy on a bicycle cruising at 30MPH. He had a helmit and leater jacket on. Funny thing was he wasn't peddling. As i passed him i saw he had a gas engine on the back of it.
    Anyways, good luck with the Dooputer. Im working on a floatputer
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  9. #59
    Oct 2006
    Quote Originally Posted by metwono View Post
    that doesn't seem very smart to me - hard drives have tiny vents on them and they need access to that air. that was one of the problems with dunking our mobos in transformer oil for cooling purposes. it'd been suggested to simply cover those vents, but common consensus was they were there for a reason.
    the rest of it, sure, great idea. but i'd have used compact flash for storage. :/
  10. #60
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by fwaggle View Post
    If you have been arround long enough... you would have seen an overclocker using mineral oil and submerging the entire PC in it.... worked just fine.
    TruckinMP3
    Read the FAQ!
