Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Water Resistant computer
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    I was looking around the net and found this, it may have been brought up before, but figure I'd post it any way...
    http://www.visson.com.tw/en/products...ing/iceman.jsp
    Would be really helpful for a boat, its a fanless, ventless computer that water resistant...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Newbie RoadRat2's Avatar
    Jan 2005
    Reading Berkshire U.K
    Hi would be good if it was water Resistant sorry to say it's only Splash RESISTANT.
    How about fiting a pc inside a Peli waterproof case this would be waterproof.
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    the under water images are photoshopped, they would be better off, putting it aquarium with fishies, and demonstrate it runnung under water, while playing some application on monitor
    Fanless procesoors are okay, but 2.5 hard drives is a diiferent story
    Yev
    R. T. F. M
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    LOL.. Go for it.. I wanna see you hookup mains power to a pc that's floating underwater in a pool. hehe..
    CAR INFO HERE
    "He who dies with the most toys, wins".
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    people submerge pcs in distilled water frequently, i don't see why people dont just do this for boat pcs. Obviously saltwater wont be good for the pc......but if its in its own water tight plexi fish tank......you should be good. similar to the idea of the gel pc
    PC Components:
    My work log
    Jan 2005
    How can you submerge a pc in distilled water? It still conducts electricity. Will still fry it. The only thing that you would be able to get away with is oil as it's not a conductor or electricity.
    CAR INFO HERE
    Dec 2004
    Maryland
    distilled water will not conduct electricity, but will eventually ionize........and eventually will.
    I've seen a system that ran for a few weeks on pure distilled water, but a lot of people will use oil instead. Oil is a better alternative.
    PC Components:
    My work log
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by Peoples
    As long as it's a mineral oil. Vegetable oil will do something possibly worse than ionizing...it will eventually turn rancid. Ugh.
    Nov 2004
    South West
    the main issue on the home pc forums at the moment is quite cooling.
    I reckon you would have to fill the box with oil (and put a heatsink on the outside) if you want a water proof box otherwise the computer is gonna give you an onboard oven and cook itself.
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Placentia, California
    Quote Originally Posted by hotponyshoes View Post
    You could also use something like this:
    http://hengruisi.en.alibaba.com/prod...r/showimg.html
    Then you could run the tubes through the case and then seal up the holes that the tubes would go through, then it wouldnt be a big deal if the fan got wet. In fact, you could even get crazy and mount the reservoir/radiator on the side of the boat below the water line, or somewhere it would get a good airflow and eliminate the fan altogether.
    Another alternative (a bit more ghetto) would be to use the same type of idea, except put the computer in a standard case, then stick the whole thing in a trash bag and then stick the hoses out the top of the back then cinch up the bag opening around it. That would keep the computer dry.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
  1. The legalities of wardriving.
    By PURDooM in forum Wireless Communications
    Last Post: 01-29-2008, 06:26 PM
  2. Remotely turn on computer (not necessarily car)
    By Triggerhappy in forum Power Supplies
    Last Post: 06-22-2006, 01:23 PM
  3. What kind of computer to pick
    By pulz in forum Newbie
    Last Post: 02-02-2006, 05:08 PM
  4. Computer Crashed?
    By Rocky388 in forum General Hardware Discussion
    Last Post: 11-30-2005, 10:39 PM
  5. Replies: 5
    Last Post: 11-08-2005, 10:04 PM
