Results 1 to 10 of 16
Thread: One reported problem
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    Quote Originally Posted by monteiro51
    Hi Heather
    I bought the BoomzBox HD Radio and had it for a week now, the problem that Iím having is that
    the sound doesnít come out the rear speaker. I did the setup the way it was instructed and still
    no sound for the rear (only in the front). Is there something that Iím doing wrong?
    Thanks for you're help
    Jan 2008
    i am not familiar with the boomzbox, or its setup, but..
    do you get audio from other sources on the rear speakers?
    typically, this is a motherboard audio setup issue, so try checking the audio setup of your motherboard-- sometimes it is called "enable rear fill"
    Low Bitrate Dak446's Avatar
    Jan 2010
    If you can, pull your speaker out and check it w/ a DMM, and also check your leads to see if you're getting AC power to your speaker. Chances are, it's not the HD Radio tuner's fault
    MySQL Error
    Oct 2004
    soundman98, has it right, its ONLY 2 channel audio... just like just about all other audio (mp3s and such, not counting MOVIES with 5.1 surround) its how the sound card handles playback of two channel audio...
    yes some sort of enable rear fille...
    what audio system do you have?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    he asked me about that before purchase and i told him the same thing. Its a 2-channel device, and whether or not it plays to all speakers is 100% dependent on your audio drivers and hardware.
    Live mp3Car Facebook Chat
    MySQL Error
    Oct 2004
    maybe we can help him still..
    i think one can use Virtual Audio Cable too, to solve this issue
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jan 2008
    Quote Originally Posted by mitchjs View Post
    if i am not mistaken, VAC is only going to be usefull if the OP uses a program like console($50) or audio mulch($150)-- neither of which are cheap when compared to the $5 in splitters that will do the same thing..
    or am i missing something with VAC?
    Jan 2010
    Quote Originally Posted by soundman98 View Post
    I do get sound from the rear speakers when playing other music... I also have the Directed HD radio box and that works fine thru all speakers. Iíve tried all different ways to setup the sound properties. Iím in away sorry that I purchased this product, i didnít have this much headache with the Directed HD. I was just trying to save the line-in spot for something else. i think maybe the drivers for the boomzbox need to be looked at to see if that the problem
    MySQL Error
    Oct 2004
    monteiro51, its all on how your audio system on your pc works...
    i know i answered this in another thread... i cant remember where
    but since you didnt tell us what kind on audio system you got
    i will assume Realtek HD Audio
    keep in MIND, MOST AUDIO is 2 channel, RIGHT and LEFT!
    radio is stereo, 2 channels... right and left!
    no rear, like in a modern movie...
    so... if you want rear sounds, you have to tell something on the pc how to do it
    in REAL car stereos they use a "FADER" to split the same 2 channels to 4 channels
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jan 2010
    It is the Realtek HD Audio system. I understand that I have to tell the system how to handle
    the 2 channel audio but I don't have the same problems with other sounds. Iíll just have to play around with it a little bit more or just use a y cable one for front and one for rear
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
