input on pc level too loud?
if running vista or windows 7, did you run the script?
if xp... then its prob not a pc input level
I just recently purchased a BoomzBox HD and setup everything.
Now everything is working except all my stations sound like crap and has a lot of static and distortion. I know my setup is good because I use to have a Directron Hd radio setup before changing and sound was clear aftr I did the ground wire mod for the box. Anyone offer help on what I could have done wrong or do I have a defective unit?
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Yes running windows 7 and ran your script along with using the latest 2/10/10 drivers. I do notice that when I am just listening with mp3 i can hear a little static and buzzing unplug the hdradio.
So basically my radio works but I get a lot of buzzing, static coming from the HD radio that I cant use it. Tryign to figure if this is mysetup problem or or is it the hd radio box itself.
I rember the directron had this problem before and I had to solder a ground wire inside the box and it fixes teh issues. I am now using the BoomzBox HD and getting the same problem sort of and the volume is really loud.
check your volume level!!! on the recording devices HD Radio
should be at 4, NOT 100!!!
i have seen the script not set it right every once in a while
drivers have nothing to do with audio
also, this statement makes no sense " I do notice that when I am just listening with mp3 i can hear a little static and buzzing unplug the hdradio."
no nothing releated to gnd wire, this box doesnt have its audio floating
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Thanks for your help I will try the audio level to see if it fixes anything. I really wanting this BoomzBox Hd to work so far this Hd radio is perfect if I can just get the sound working correctly.
Thanks for the help problem is fixed. My recording volume was at 100 and I dropped it down to 2 and sound is good. Was going to use your new script but went ahead and did it manually.
yea.. i need to see if i can adjust that a bit better programaticlly
the script is a "hack"... that simulates clicks and tabs to do it...
i do CLEARLY show you in the instuction pdf with the tuner
which of couse you read 2 or 3 times
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I have spent few days to solve thes two problems and I still don't have any luck
1)The speakers seem to be distorted when I am listening to radio, especailly the AM cahnnels. I am using Win XP 2SP OS. I had tried on Win 7, even I adjusted the input volume to less than 4 on Win 7, the distortion still existed. (Not too much distortion, but noticeable). And there was no input adjustment on Win XP.
2)When I listen the radio with the Boomzbox HD application it seems to be fine, but once I use the Ride Runner (the most update 03/2010), the tuner still turns on but a lot of static and noise jam in. I exits the radio the static and noise are still there even when I am only listening to MP3. It seems once I run the RR the static and noise will jam in. I need to select no Radio from the RR configure inorder to get the static and noise away. What would cause this problem? Is it the RR or the Boomzbox driver?
Please Help![]()
read my reply in the rr forum
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
