Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Need some installation help...
  1. #21
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    right. i meant the mobo is told to shut down immediately. i put it at 2 minutes just to be 101% certain to rule this one out.
  2. #22
    MySQL Error
    Oct 2004
    any pictures of your massive setup?>
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #23
    Feb 2010
    Quote Originally Posted by S4Per View Post
    it's wired to my carnetix 2140 secondary output (I have 2 PSU's).
    I think I'm good there, but I'll validate that I have this particular 2140 coming on prior to the main 2140 that powers my mobo comes on (via the delay on setting on the PSU). They both trigger off the same ACC line.
    Had some time to finally document my setup, btw...kept on forgetting how I had it setup..lol.
    Thanks for the information. Great
    _____________________
    Virtual Assistant
  4. #24
    Jan 2004
    Seattle, WA
    re: pictures...I have some, actually working on doing more detailed ones there also (once I get everything worked out here).
    In-dash 7" sunlight readable screen:
    Center console:
    DLS subwoofer where OEM nav and CD changer used to be. Also - Zapco amps mounted on trunk ceiling:
    Now you see it:
    Now you don't ..fyi - I added a fan vent hole in the panel cover since this picture right above where CPU is.
    All the other stuff in the wiring diagram is hidden. One picture I don't have: in glove box, mounted on the top of it - slot load DVD...looks real nice, and preserves all of the space in there.
    Now, I'm on to Win7 challenges...I'll start a thread about that, not having a great time there
  5. #25
    Feb 2010
    I am disappointed. I really thought this thread would help. It started out with my same problem...but with ALL applications, not just CF. No sound at all, but the radio is working.
    Then people just started saying that it worked in CF, but I never understood why.
    I posted a new thread in the forum asking this. I hope someone can help.
    No SOUND. Definite Codec Problem. Help!
    DJ
  6. #26
    MySQL Error
    Oct 2004
    REMEMBER 1st time you plug it in, windows thinks you want to playback your audio though this device, which of course you cant, reset your DEFAULT PLAYBACK DEVICE
    start with the simplest BoomzboxHD Software, supplied on the CD
    Install it...
    run it, and it should automaticly find the device, if it doesnt
    right click, setting, enable audio engine, enable monitor, pick USB Audio CODEC
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. looking for audigy nx 2 installation disc
    By americasfuture2 in forum General Hardware Discussion
    Last Post: 08-18-2008, 04:01 PM
  2. Replies: 0
    Last Post: 11-26-2006, 07:25 AM
  3. '88 Dropped Mini Xbox installation in progress..
    By edraws in forum Show off your project
    Last Post: 06-24-2006, 06:23 PM
  4. Zonet USB dongle installation problem
    By tibby01 in forum Wireless Communications
    Last Post: 03-26-2006, 07:48 PM
  5. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
