Results 1 to 6 of 6
Thread: problem will not find radio
    Jan 2010
    Exclamation problem will not find radio
    i installed all the drivers and everything and no matter what i do i use centerfuse and it just sits there when i try to use the radio so i downloaded the stand alone app and then the app search for the radio and says not found when auto is selected then when u point it to the comm number it just sits there and does nothing it say searching im stumped any help on this would be good thanks
    MySQL Error
    Oct 2004
    does the radio show up in the ports section of device manager
    did you connect 12volts?
    not to mention os would be nice too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jan 2010
    It shows up in device manager the port is 25
    the 12 volt power is connected
    My os is windows 7
    MySQL Error
    Oct 2004
    if all is well, boomzboxhd software should be able to find it on AUTO
    if not.. 1st try another pc
    check 8 pin minidin for broken/bent pins
    there is a small fuse inside the box (right by a notch, label pf1) measure 12v there
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2005
    Any resolution to this problem? I'm having the same issue with BoomzBox program.
    Thanks.
    MySQL Error
    Oct 2004
    his posts are from 3 months ago... most likely solved his problem...
    and just forgot to post his solution
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Hardware Review: BoomzBoxHD
    By Bugbyte in forum Mp3Car Blog Talk
    Last Post: 01-25-2010, 05:53 PM
  2. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 03:01 PM
  3. new member, new radio, new problem
    By dragonaile in forum Car Audio
    Last Post: 04-07-2009, 07:21 PM
  4. IG3 trouble and weird radio boot problem
    By TheMainFrame in forum Road Runner
    Last Post: 11-17-2007, 12:30 PM
