Results 1 to 8 of 8
Thread: MJS Gadgets MP3Car.com HD Radio (Windows 7 x64 Drivers)
    Low Bitrate Gecko483's Avatar
    Feb 2008
    Anaheim, CA
    I got a message when i boot up and log in to windows.
    Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
    Do I have to disable driver signing every time I boot for this to work, or is there a signed driver available? I used the driver downloaded from your skydrive.
    I am going to uninstall the driver and delete it, then reinstall it just to make sure.
    MySQL Error
    Oct 2004
    doesnt sound like your using my drivers
    they are signed
    did u install another FTDI device, which could OVERWRITE the SHARED FTDI system files?
    a reinstall of them, would correct that.
    also use the ones on the supplied CD...
    (they are the same as skydrivve)
    or windows update...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2008
    Anaheim, CA
    Something must have messed up the first time when i installed them, because after I removed them and reinstalled them, the drivers worked fine.
    MySQL Error
    Oct 2004
    if you install another FTDI device make sure u use same version FTDI drivers
    if its OLDER... and possible different version
    usually its a BSOD
    but it will also break signature
    installing, my drivers last will make sure everything is up to date...
    prob good to go now...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2008
    Anaheim, CA
    When I run the application Boomzbox HD - 1.3.1.2 - MP3car.com, I get a pop up window when the application powers up the radio. It also happens if i power the radio off, and then back on:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at HDRadioDemo.HDDemoMain.AudioDiscover()
    at HDRadioDemo.HDDemoMain.HDRadioCore_HdRadioEvent_Po weredOn()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    BoomzBoxHD
    Assembly Version: 1.3.1.2
    Win32 Version: 1.3.1.2
    CodeBase: file:///C:/Program%20Files%20(x86)/BoomzBox%20HD/BoomzBoxHD.exe
    System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Design
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    BTW: Thanks for the quick response. I believe the drivers got corrupted, as i was installing over wireless with a low signal.
    MySQL Error
    Oct 2004
    no audio devices in your system?
    i would check device manager, in sound devices, you should have
    a USB Audio Codec
    also unrelated, but prob wont except
    BoomzBox HD Software - Updated 4/4/2010
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2008
    Anaheim, CA
    All i got to say is improper setup, I forgot to run the setup file that sets all the settings, plus i was remote logged in to the machine from the house. Soon as I logged in locally, and ran the setup file that changed the settings, all was well. I doubt you ever intended someone to run this application via a remote desktop session.
    Thanks for all the help, I love the HD interface !
    MySQL Error
    Oct 2004
    AH, yes.. i never considered that
    with remote desktop you could say leave audio at remote computer
    (its an advanced option)
    and then it would work
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 01:26 PM
  2. HD Radio + Video Selector = Distortion
    By joeyalex in forum Car Audio
    Last Post: 04-22-2010, 09:48 PM
  3. HD Radio
    By pcullin in forum Car Audio
    Last Post: 09-01-2008, 12:31 PM
  4. Phx Area HD Radio Question
    By 99WhiteSleeper in forum Car Audio
    Last Post: 06-23-2008, 12:27 PM
