Hello,
So I have been fiddling around with the Boomzbox for a while now and finally got it to work properly. I turned off buffering because all stations were getting a looping effect. I would hear certain parts of a song and a few seconds later the same audio. What is the point of buffering anyway? The main problem that I now have is that I do not receive a lot of stations. What could be a cause for this? I have a 2006 Honda Ridgeline with an aftermarket am/fm
radio adapter that connects to the stock
wiring harness then plugs into the Boomzbox with it's standard
motorola adapter. Where does the blue wire need to be connected? I'm not sure if I have it connected properly. I'm guessing it's not connected properly and the amplified antenna is not being powered or turned on, resulting in few stations being picked up?
