Results 11 to 20 of 22
Thread: USB Audio codec just isn't there...so no sound
  1. #11
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    Hi ramrod,
    Let's see if Mitch can help you trouble shoot this first and we'll replace it if necessary. Mp3Car will cover shipping both ways this time. This is very rare for two units to be having problems. Thanks for your patience and understanding in the matter.
    Stephen
    Have a product you would like to sell on the mp3Car Store? PM me for more information.
    Have a car computer question? Ask me by emailing the store.
  2. #12
    Sep 2005
    Usbview shows two devices as it should.
    Device Manager shows a USB device and a comport, along with a USB Audio Codec and two HID devices.
    All this stuff seems to work correctly whereas with the previous one I didn't see the USB Audio codec.
    Something seems to be going bad when dealing with the tuner. The previous unit communicated with the tuner just fine. I don't hear the relay click on or off on this one.
    I'm leaving town immediately after work today, so I won't be able to mess with this again until next week.
  3. #13
    MySQL Error
    Oct 2004
    ok, looks good, at this point, i doubt any issue with the interface
    but we can confirm that, if needs be
    did you only swap the interface? or did you send back the tuner too?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    Sep 2005
    I had to return the entire setup per the return policy. So no chance of swapping individual components out to troubleshoot.
    So to be clear everything involved here is completely "new".
  5. #15
    MySQL Error
    Oct 2004
    dang... ok...
    hopefully you can follow me here, you seem to understand this stuff
    unplug the tuner box and cable, from the interface box...
    got a simple terminal program?
    here is one... (its great too)
    http://sites.google.com/site/terminalbpp/
    run that, and pick ur comport (5)... and click connect (any baud rate will do)
    with a little piece of wire, jump pins 3 & 6 on the 8 pin minidin jack
    ok, where is pins 3 and 6... easy
    looking at the jack on the usb interface box
    Code:
    8  7  6
    5  4  3
      2  1
    so its the 2 RIGHT pins
    now type in the transmit area (which is at the bottom and dark grey)
    anything you type should echo back in the receive area
    if so, the interface is good... bot TX and RX verified
    hopefully you can do that before you leave... else i do have plan b
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #16
    MySQL Error
    Oct 2004
    2 top right pins
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Sep 2005
    Won't have a chance to do this until I get back next week.
  8. #18
    MySQL Error
    Oct 2004
    if u can find a sec to try it, then we would know, and prob can get sorted by the time you come back
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Sep 2005
    OK, burning up my lunch break on this....
    Did that and it echoes back just fine. So the DIN cable or the tuner are the culprits?
  10. #20
    MySQL Error
    Oct 2004
    sorry, but im trying to help you before u leave...
    yes, you are right, you could confrim din cable, when looking at a FEMALE mini din
    the 3 and 6 pines on the LEFT so top left side pins
    short there, and test for echo (ooh rush album)
    i never seen a bad din cable
    unless someone jammed it in wrong and bent a pin over
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 6
    Last Post: 03-10-2010, 08:29 AM
  2. PCI vs USB Sound Card
    By Maegnas in forum Car Audio
    Last Post: 08-08-2008, 01:59 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
Tags for this Thread
