My wishlist:
Can you make this "activate recognition" as customisable as possible. I think each CarPC will have a different setup so not everyone will have keyboard/
mice at hand while driving. Same with deactivation, I'd like to be able to configure the timeout and/or a different keypress.
My ideal configuration for this would to allow the user to chose which is the best way to active BSR, one of the following:
1. Press a mouse (right/middle click or scroll wheel)
2. Press a screen button in RR or FP. I'll create a plugin for RR if this is implemented
3. Press a keyboard button
I'd like to be able to choose between these 3 options and also set the exact keypress/mouse click in the settings. Also set the timeout for pausing the
music in the settings file after activation.
Deactivation, I'll like to be able to choose from these in the settings file:
1. timeout to deactivate
2. keypress
3. mouse click (right/middle click or scroll wheel)
4. RR or FP button to deactivate.
Fonally, on some command it would be useful to have a dialog box pop up to give a response (either as text or speech) and then give focus back to the original app. I'd prefer a text box poping to the front to say that the certain commands were recognised (not every command). With each command I'd like to be able to set the response, for example in the vocab files:
[Independent]
play music=(alt)p|TextResponse="Playing Music"
shutdown=(alt)x|VoiceResponse="Powering Down do not forget the inverter!"
