Can you create a log file will all the commands recognised and the ability to disable the execution of the commands.
The reason I ask is because I want to figure out command keywords that are being recognised just for car noise and MP3 playback. What I'd like to do is leave the car running for 20 minutes with MP3 full blast (normal volume!) and leave BSR to see what it does. At the moment I have to sit there and see the balloon popups or status bar of the app. Ideally I'd like to go away and have a coffee then come back and see what commands are failing on a regular basis.
While this test is going on I'd like to be able to turn off the execution of any commands BSR recognises. Ideally if BSR can come back with statistics on which commands are worse that would make my life very easy
