Originally Posted by LordSnow
No, delay can be programmed by the [pause]100 command. Duration will be how long the button is held down. You would probably put down 0 for just a standard click.
I'm not sure if duration would be useful though...
Originally Posted by FunkDaMonkMan
excellent,
Thats all I needed to know that it was in the manual/Help !
http://www.mp3car.com/vbulletin/classified-archive/70918-fs-ft-laptop-memory-internal-laptop-wifi-card-hd-bluetooth-post759606.html
FS FT Thread
96 Eagle Talon TSI AWD
Custom blue LED interior and Dash, Buddy club2, ViS Fenders, Phillips Ds2 Bulbs, Valeo-Fresnal ECE H7s, Mitsubishi Ballasts
Bruno Speech Recognition - Advanced Speech Recognition designed to control any program. Extra support for FrodoPlayer and Winamp.
Originally Posted by Nighcrawler
I am getting the same error, i did install the speech sdk 5.1, but no luck, is there something else that I have to do after install speech sdk5.1?
try un-installing, and re-installing to the default directory.
reinstall Bruno Speech Recognition or the sdk? i did both, still same problem
hm.. are you installing to C:\program files\bruno speech recognition ?
What OS are you using?
Where did you get the SAPI?
yes, i am using xp, and i got the sapi from your help file where it say click here in the requirement section
Hi good program
But Just wanted to konw a few add on possibilities..
1........If i use the command to start Frodo Player -- it sure does. Now my FP is configured to start with MENU screen ON always.. Here on the Menu screen if i give command Radio it works since u have provided a few FP commands. How about if i wanted to start MEDIA or CAMERA from the MENU screen... how do i configure this
2...... If i want to use the Voice recognition for Calculator mode to type in number while i say how do i configure this part...
ex----- ( 152 X 25 = )
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
HI ok this is funny.. I use the command to start a program.. it does it a few times and then i see THE SPEECH RECOGNITION has stopped all to gether till the time I toggle DISABLE / ENABE voice commands..and it starts functioning ok again for a few times..
also it keeps attempting to recognise FALSE commands and gives outputs of what shes trying to hear.. Like Enable 1 ; Enable 2; Enable 3; PAUSE PAUSE
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
Ok Heres is some kind of Bug .. Maybe not sure..
If i play FP and give a command for NEXT MODE or play .. it some how starts SAYING PAUSE and kepps douing it till the time i exit the SPEECH SOFTWARE.. and if i re start and come to the same point it agan gets stuck on the PAUSE command for ever.. till i exit every thing
why is this so
any help
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
