Results 11 to 20 of 23
Thread: bu-353 upside down, does it matter?
  1. #11
    Jan 2008
    Southern Calif
    It's the same thing as an XM or Sirius antenna, they are meant to be mounted in one direction.
  2. #12
    FLAC Marvin Hlavac's Avatar
    May 2005
    Quote Originally Posted by Tidder View Post
    hmm... so I had mine upside-down on the 6 hr trip home, I didn't experience any difference. Signal strengths dropped a tad, but not much...
    LOL, that reminds me once I was using a Bluetooth connected SiRFstarIII based GPS receiver with my PC, and I didn't even realize the unit was in my pocket while I was driving. It worked flawlessly during the whole trip .
  3. #13
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Upside down it's probably working like a badly beat up satellite dish. It's catching the signals bouncing off all the metal parts in the car. It's really designed to be facing up.
  4. #14
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    OK, I know this thread is kind of old, but my Hiacom BT407 GPS is driving me crazy. I cant use it with BT because the bluetooth stack CF uses cant use GPS and Phone (or at least I dont know how too). I see alot of people have the BU-353 and it is fairly low priced and wont break the bank. Although I have a USB to Serial cable for the BT407, it doesnt work because when I come out of hibernation it will act like its not coinnected. I tried Hibernation Trigger, and that doesnt work, so I figure just replace the darn thing.
    Do any of you have this issue with the BU-353, with it not showing up after hibernation? Is this unit 100% USB, or is it were it installs as a Serial to USB device. If not I think I will buy it then.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #15
    Mar 2004
    Florence Yall, BFKY
    I never have trouble with the BU-353
  6. #16
    Jul 2008
    Quote Originally Posted by Curiosity View Post
    Ditto. I'd recommend upgrading to SIRF tho.
  7. #17
    Jul 2007
    Miami
    Quote Originally Posted by fridgemagnet View Post
    I reading the stats and it says its has a SIRF III chipset.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  8. #18
    Mar 2006
    Colorado, but Canadian!
    I have a BU-353 too and it is awesome. And yes it is SIRFIII.
    The pharos 360/560 are pretty good too. (SIRFII/SIRFIII and the 360 glows blue )
    All USB is serial... so yes it is serial. Never had a problem from resume. Although from what I have seen around here half the time if you have resume issues it is the motherboard. Other time it is the device. So it will fix it if you are lucky, but it wont neccessarily work.
    1.9in x 2.9in -- 47mm x 73mm
  9. #19
    Jul 2007
    Miami
    Quote Originally Posted by 2k1Toaster View Post
    I think maybe this time its this GPS reciever. I do have to have my things plugged into certain USB ports. Like my Sound Blaster has to be on the USB 2.0 PCI CARD Port, so do all my touch panels and pointers. Then everything else goes on the onboard ports, but at least something ports on a port. No matter what port I put this GPS on, it doesnt resume at all.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  10. #20
    Jul 2008
    Quote Originally Posted by HiJackZX1 View Post
    True but it doesn't use Sirf by default, you need to use SiRFdemo to change it into SiRF mode.
    You can also reset the unit through that tool, which may help with your resume problem.
  1. Wireless links - do BOTH ends matter?
    By agarbino in forum Wireless Communications
    Last Post: 07-26-2007, 06:43 PM
  2. Bu 353
    By sebberry in forum GPS
    Last Post: 09-04-2006, 10:35 PM
  3. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 09:52 PM
  4. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 03:56 PM
  5. screen mounting upside down
    By alienjj in forum General Hardware Discussion
    Last Post: 02-01-2004, 01:04 PM
