Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: bu-353 upside down, does it matter?
    Jan 2008
    I bought a globalsat bu-353 and was going to mount it on the dash, but decided it would look cleaner and have a better reception if I mounted it in the corner of the top passenger windshield.
    I'm getting slow response from the gps directions. Sometimes it will refresh every four or five minutes. Could it be because I have the receiver mounted upside down? I looks like a hockey puck with one rounded side and one flat side. I mounted it with the flat side against the windshield, so I'm wondering if it matters which way you mount it.
    Mar 2006
    Colorado, but Canadian!
    As long as there isnt metal in its "view", it will be fine.
    Do you have a metallically tinted windshield? In my Honda, the windows all have metallic tint on them (4 sides and front back) so signals inside are crap. A good way to test it is to slap it out the outside of your car (its magnetic so it wont be hard or damaging) and see if reception improves.
    But the 4-5 minutes you talk about is after it is warmed up right? How many satellites are you seeing and are they at a good strength?
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    satellites
    I tested it at my home location and I'm seeing 7 out of 10 satellites. It just seems like the response is too slow. By the time I reach the destination the gps is still trying to catch up to me.
    Mar 2006
    open up a program like XPort. Lock into that COM port and see the data it displays in the bottom. Do this without any of your other programs running.
    If it displays constantly changing data, the gps is working and the backlog is your system.
    What hardware are you running?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Hmm... I'll have to try this with my BU-353. I've got to take a 6 hour trip back home tomorrow, so I'll see if mine exhibits the same behavior. I'm kinda with 2k1 on this one tho... maybe it's the system itself. Does it correctly update when normally sitting or stuck on the outside of the car? These have magnetic bases, I wonder if there is any type of plate or something inside of it to block magnetic interference that could also be blocking good gps reception, or if the magnet is too weak to cause problems anyway...
    Tidder
    Try RevFE
    FLAC Marvin Hlavac's Avatar
    May 2005
    I think the orientation of your BU-353 matters. The antenna is on the round side of the unit. The round side should face the sky for better reception of the satellite signals. However, since the BU-353 (w/its SiRFstarIII chipset) is quite sensitive to weak satellite signals, I doubt you will see substantial improvement of the issue you have described. Your car's metallic tint, as 2k1Toaster said, may be preventing RF signal from getting into your GPS receiver, or there may be some interference, or other problem.
    Jan 2008
    Southern Calif
    Thats what i was thinking too, the antenna patch is on the top side. Just got one of these too as well.
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    I sure hope so because that is the way mine is being mounted.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Sep 2003
    New Mexico, USA
    hmm... so I had mine upside-down on the 6 hr trip home, I didn't experience any difference. Signal strengths dropped a tad, but not much...
    Tidder
    Try RevFE
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Mine is mounted nearly vertical, facing back behind the car rather than upward. It works as well that way as facing up. I never tried upside down though.
    ~Jimmy
  1. Wireless links - do BOTH ends matter?
    By agarbino in forum Wireless Communications
    Last Post: 07-26-2007, 06:43 PM
  2. Bu 353
    By sebberry in forum GPS
    Last Post: 09-04-2006, 10:35 PM
  3. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 09:52 PM
  4. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 03:56 PM
  5. screen mounting upside down
    By alienjj in forum General Hardware Discussion
    Last Post: 02-01-2004, 01:04 PM
